installing spindles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blaise22, Aug 6, 2010.
  1. Aug 6, 2010 at 7:49 AM
    Blaise22
    Blaise22 [OP] Well-Known Member
    Blaise
    California
    09 prerunner trd offroad
    Camburg 4.0 race spindles, coilovers, 285/75/16 Yokohama Geolanders mounted on 16" KMC Hoss wheels, Aero Turbine 2525
    hey guys i have my spindles in my garage waiting to be installed. Do I need any special tools to get this done? and can someone please explain to me how to bleed the brakes?
  2. Aug 6, 2010 at 8:19 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
  3. Aug 6, 2010 at 9:53 AM
    Blaise22
    Blaise
    California
    guess not
  4. Aug 6, 2010 at 11:08 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    No you don't need at special tool
    Bleeding with VSC
    Without VSC
  5. Aug 8, 2010 at 9:59 AM
    Blaise22
    Blaise
    California
    this might be a stupid question but I just got my stock spindle off and I dont see any bolts, what do I need to do next?
  6. Aug 8, 2010 at 10:34 AM
    Blaise22
    Blaise
    California
    anybody? im stuck
  7. Aug 8, 2010 at 10:35 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    hmm. Did your spindles come with the bearings already pressed in?
  8. Aug 8, 2010 at 10:36 AM
    Matic
    Tricky Dick
    Easley, SC
  9. Aug 8, 2010 at 10:37 AM
    Blaise22
    Blaise
    California
    no there the camburg spindles. I need to remove all of that from the stock one, I just dont know where to start.
  10. Aug 8, 2010 at 10:38 AM
    Matic
    Tricky Dick
    Easley, SC
    Good luck man. Way to complicated for me.
    The write up looks pretty good and very precise though.
  11. Aug 8, 2010 at 10:39 AM
    Blaise22
    Blaise
    California
  12. Aug 8, 2010 at 11:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They are 17mm bolts. And they are behind the shield.
  13. Aug 8, 2010 at 1:35 PM
    Blaise22
    Blaise
    California
    oh gotcha how do I get the shield off?
  14. Aug 8, 2010 at 1:43 PM
    Blaise22
    Blaise
    California
    actually first off how do i get the rotors off?
  15. Aug 8, 2010 at 1:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Take off the brake caliper, and the rotors will pop off.
  16. Aug 8, 2010 at 2:08 PM
    Blaise22
    Blaise
    California
    haha i was hoping you wouldnt say that they are not budging at all, is there a tool that will get them off?
  17. Aug 8, 2010 at 2:11 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    not trying to be a dick but u might be over your head, saying that to get the caliper off... there should be 2 bolts that face towards the truck that you will loosen and pull out and that will allow the caliper to slide off
    Good Luck
  18. Aug 8, 2010 at 2:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your 2 hands are the tool. If they are stuck on, you can hit the rotor with a rubber mallet to help loosen it.
  19. Aug 8, 2010 at 2:14 PM
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    A heavy rubber mallet. Not sure if Toyota uses them, but some have a flat head screw that needs to be removed first.
  20. Aug 8, 2010 at 2:14 PM
    Blaise22
    Blaise
    California
    never asked how to get the caliper off but thanks
