Installing Subaru / Kicker tweeters -- Questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChukarBob, Sep 14, 2020.
  1. Sep 14, 2020 at 6:46 AM
    ChukarBob
    ChukarBob [OP] Well-Known Member
    Bob
    Seattle
    2017 TRD Sport DC LB 4WD AT; preceded by '15 Subaru Outback & 2007 Tacoma SR5 DC LB 4WD AT
    First of all, let me explain I'm not very handy with mechanical & electrical repairs and upgrades. But I've looked at a few YouTube videos on installing the Subaru / Kicker tweeters in the dash of my 2017 TRD Sport and I think I can handle this! I've bought the speakers and a cheap set of trim tools and I'm ready to go.
    A few questions before I start:
    > Is it necessary to disconnect the battery? What will I lose or have to reset if I do? What's the worst that can happen if I don't disconnect (loss of life or disfigurement from an airbag blowing up in my face?)?
    > Do you have to remove those pillar covers to remove the grills over the speakers?
    Thanks for your responses!
    Follow up question -- Would replacing the front door speakers be more complicated / difficult?
  2. Sep 14, 2020 at 7:45 AM
    Shellshock
    Iowa
    I didnt disconnect the battery. Just make sure the truck is turned off and you’ll be fine
    I dont think i had to remove the A pillar, but its been quite a while since i did mine.
    Skydvrr likes this.
  3. Sep 14, 2020 at 7:47 AM
    Tacospike
    Two Trucks
    I didn't disconnect the battery, i did remove the A pillar
    shakerhood and Cpngo like this.
  4. Sep 14, 2020 at 7:54 AM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    You do have to remove the A pillar covers to be able to remove the speaker covers.
  5. Sep 14, 2020 at 7:54 AM
    jjglass535
    jjglass535 Well-Known Member
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    There is no need to remove the a pillar, the speaker grills just pop off. 2 - 10mm bolts and a plug and your done
  6. Sep 14, 2020 at 7:55 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    For the speakers, the battery is no worry. Disconnecting the HU or other similar work, I would disconnect.
    Yes. You have to pull the pillar. The grille won't come out otherwise. Also, install the grille first or it will scratch the pillar trim.
  7. Sep 14, 2020 at 7:59 AM
    jjglass535
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    The a pillars are not in the way. I've had 4 different sets of tweeters in there before I found what I like. It takes 2 minutes. And with the truck off is all you need. Been building systems for years and never had an issue replacing any speaker with the truck off
  8. Sep 14, 2020 at 7:59 AM
    Shellshock
    Iowa
    The only time i ever disconnected my battery is when it was in the way of other work i was doing :anonymous:
    Ch78, TurdTaco64 and tonered[QUOTED] like this.
  9. Sep 14, 2020 at 8:01 AM
    jjglass535
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    Or installing/removing an amp !
  10. Sep 14, 2020 at 8:11 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Angry pixies and I don't get along well, so I go a bit overboard. Smoked a radio that I was installing for a GF years ago, along with many other failures with moving electrons. :D
    BlkTaco47 and Shellshock[QUOTED] like this.
  11. Sep 14, 2020 at 8:41 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Agreed. I've even welded on stuff on the truck w the battery connected still :anonymous:
    Tacospike likes this.
  12. Sep 14, 2020 at 10:30 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I didn't disconnect the battery but did remove the A Pillar Covers, the passenger side was slightly more difficult because of the automatic headlight sensor.
    tonered and Tacospike like this.
  13. Sep 14, 2020 at 11:23 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I did the subura tweeters any the highs were great but then I changed them out for a 2 way speaker/tweater. So much better than just a tweeter alone. Night and day difference, might want to consider them.
    SubZombie and shakerhood like this.
  14. Sep 14, 2020 at 12:02 PM
    SubZombie
    SubZombie Well-Known Member
    South East
    2019 Voodoo TRD Pro
    Yea. I think it's mainly old folks on here who like the straight Subaru/kicker swap (because it amplifies the hell out of higher frequencies they can't hear well). The dash speaker is a mid range driver not a tweeter, putting a tweeter there without adjusting crossover settings is going to distort the hell out of the mid range because the speaker is being sent sounds it can't accurately reproduce which is why the sound from doing this is super bright. It's why you see posts on here over time from people who do the swap and like it initially and then realize it doesn't sound right. I do think the truck needs a tweeter but swapping them in place of a mid range driver will just jack things up.
  15. Sep 14, 2020 at 12:08 PM
    Mister Grey
    Mister Grey The Viking of disapproval looks in your direction
    Hayward Ca
    2017 Tacoma DCLB Sport 4x4
    The Works.
    This job is most easily done at freeway speeds.
    Aaronparker001 and wrightme43 like this.
  16. Sep 14, 2020 at 12:17 PM
    VaToy
    Parts Unknown
    Agree!
  17. Sep 14, 2020 at 3:27 PM
    ChukarBob
    Bob
    Seattle
    AAAaaarrrggh! Got it about 90% complete and could not get that up-side bolt cover on the passenger side A pillar to snap into place. Right now it's held in place with electrical tape. I'm so pissed, because it was going pretty well up to that point.
    But the sound is much improved. I hear what the last few posts are saying about the sound and mostly understand. Coincidentally I am nearly 71, so I plead guilty to being an "old folk". Not much I can do about that. My hearing is still pretty good, but no doubt diminished from what it once was. No hearing aids and no need for them, according to the audiologist a year or so ago.
    Don't know what to do about the bolt cover.
    twitchhero, TurdTaco64 and tonered like this.
  18. Sep 14, 2020 at 3:49 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Pic of what you're talking about?
  19. Sep 14, 2020 at 4:49 PM
    ChukarBob
    Bob
    Seattle
    I don't think a picture would tell you much. Everything looks like it did when I popped it off. Although one of the two fasteners that fit into the holes is about 2/3 the length of the other. Don't think you could see that in a photo. So it's possible, just possible, that the shorter one just won't seat in the hole. That's my best hypothesis for now.
  20. Sep 14, 2020 at 10:32 PM
    groundball8404
    groundball8404 Well-Known Member
    NC
    2022 TRD Off Road
    Generally speaking it's not for old people who can't hear well. It works because the tweeter is playing the frequencies that are missing with the factory setup. It doesn't amplify the frequencies and the head unit is sending a full range signal to the front speaker no matter if it is the midrange that was there or the tweeter that was put in. They both have capacitors on them that block the frequencies that should not be played through it so that tweeter is not going to distort like you think. It is brighter because it is a tweeter vs a small mid. I don't know why Toyota would put a small mid in that location because it makes no sense and sounds like garbage.
    Is it the best upgrade? Not at all, but for the average person looking to improve the muddy sound of the factory speakers it is not a bad idea because it does subjectively improve the sound and it is plug and play. You can definitely get better sound from a good component set with an external amp and set crossover points, but for most the Subaru tweeter will work just fine.
    texas angler and tonered like this.
