Installing TC UCAs, quick question on grease??
Discussion in 'Suspension' started by ACE_Taco, Mar 6, 2010.
  1. Mar 6, 2010 at 11:15 AM
    ACE_Taco
    ACE_Taco [OP] Long Range Practical Marksman
    NC
    08 DBLCab TRD 4x4
    OME 885x Coils, Dakar Leafs, OME Shocks, TC UCAs, BHLM, Tailgate MOD, WeatherTec Window Deflectors, WeatherTec Floor Mats, Blacked Out chrome bumber, Satoshi Grille, Wet Okole Seat Covers
    Installing my TC UCAs today. The instructions call for a Teflon based grease for assembly. I can not find any at my local B&M. All I have is Mobil 1 Synthetic Grease. Will this not work for assembly???
    Thanks
  2. Mar 6, 2010 at 7:08 PM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    10-4 thanks bro. BTW, do you know the thread size of the Zerks? I friggin broke one off and need to replace it.....:(
  3. Mar 6, 2010 at 7:16 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Mobile 1 is ok, x2 on the teflon spray lube on the uniball, 3/8th inch zerk
  4. Mar 6, 2010 at 7:17 PM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    is 3/8" the actual thread size?? i know the nut takes a 3/8
  5. Mar 6, 2010 at 10:29 PM
    TacoSupreem
    Hayden
    Kentucky
    auto zone 3/8th zerk. take yours with you for reference.
  6. Mar 6, 2010 at 11:04 PM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    10-4, thanks fellas...
  7. Mar 7, 2010 at 10:35 AM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    Just an fyi that I went to O'Reilley AP and bought a pack of 1/4"-28 Zerks. They fit perfectly.
  8. Mar 7, 2010 at 11:13 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    x2 on the Mobil grease. You can also pick up a cheap grease gun for like 25 bucks. Those zerks were a pain. I ended up buying new ones like you guys did too.
  9. Mar 24, 2010 at 8:13 AM
    RAD
    RAD RAD Vendor
    THE RAD
    Socal
    2007 | TRD |1ST 2012+ CONVERSION
    2012 CONVERSION | A LOT OF TOTAL CHAOS & ICON DYNAMICS
    So I got a grease gun for my TC UCA and other stuff. I can't seem to get it to fit around the original Zerk.
    I'm having issues getting to fit around them and get the grease in. Are you guys saying that the Zerks from the UCA need to be replaced?
    MY TC UCA make tons of noise!
  10. Mar 24, 2010 at 8:15 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    It will fit. Just push hard. You will know it's on because you will hear a pop noise.
  11. Mar 24, 2010 at 10:30 AM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    +1 on what jdkeller said. Just push the female end of the grease gun on the male zerk. You will hear it pop. You will also have resistance pulling it off.
    The reason so many of us had trouble with the provided zerks, is because they are a bitch to get the thread started. Very easy to cross thread.
    If you are having noise, it may be because you didn't grease the poyurethene bushings before assembling. When adding more grease, do not put too much. It will cause the bushing to mushroom out.
  12. Feb 14, 2011 at 6:33 PM
    rk9947
    rk9947 New Member
    2010 trdsport double cab long bed
    Smittybilt Bullbar, Bakflip F1,Black Oval Sidesteps, Weathertec Mats, Matched rear tint,icon stage 2 w/tc uca's, full 3" catback exhaust w/magnaflow muffler and black painted tip
    so i greased my zerks and sprayed my uniball, no squeaks but as i removed my grease gun on the last fitting it took the zerk with it! Broken half way through the thread and not sure how to fix it. Have any ideas?
  13. Feb 15, 2011 at 9:08 AM
    N3ZAT
    N3ZAT Well-Known Member
    Charlie
    Coatesville,Pa.
    09 tacoma
    saws up front/TC UCA/rear AAL
    yea start by calling it a grease fitting thats what they are then use an easy out tool to remove remainder of grease fitting i have greased over thousands and thousands of fittings the worst would be to have to drill and retap good luck
