Installing Tracks and Reinforced Shells
Discussion in 'Tonneau Covers, Caps and Shells' started by rogue.tacoma, Feb 13, 2019.
  1. Feb 13, 2019 at 10:36 AM
    rogue.tacoma
    rogue.tacoma [OP] Well-Known Member
    Ed
    2017 TRD Off-Road 4x4 DCSB
    So I've researched a lot on opinions on where one should install their tracks to mount rails. I have a Snugtop Rebel with the Sportsman Package to handle 500lbs loads and like an idiot I didn't order it with tracks from the beginning.
    The dealer and everyone else charges an more than $300 just to install and at that price I'd rather do it myself.
    What I have issue with is where exactly to drill and lay the track on? Should it be just outside the honeycomb reinforced structure to avoid crushing when I tighten the bolts or just outside the honeycomb?
    Please advise, if you have pics that would be great.
    Thanks!
  2. Feb 13, 2019 at 2:39 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Yes, definitely outside of the honeycomb part. That stuff is typically cardboard (or was anyways) and will crush if you try to tighten your mounting bolts. I was told by the dealer that the reinforced part is to keep the top of the shell rigid so that it keeps its shape and doesn't vibrate and crack the paint and gelcoat. I looked at another ARE shell that was on the lot that had the tracks already mounted and got an idea where they mounted them at the factory and went from there.
    Use the kit Yakima, and probably Thule, make for this purpose and it should come with some plastic and metal nuts that are rounded so you don't gouge your head if and when you bump them. Yakima calls them "track nuts"; their website sucks but you can see them in this install picture: https://explore.yakima.com/custom-install#fiberglasstrack They advise using a small amount of silicon, not globbing it all over the place. My brother was trained by Yakima how to install the tracks when he worked at a bike shop and advised the same thing so that's what I did. So far no leaks that I'm aware of and they've been on since 2006 and I definitely haven't been gentle on them.
    I don't have any decent pictures showing where mine is mounted.
    Incidentally, I mounted some D rings under the nuts when I was installing mine so that I could use a gear hammock, overhead bungee net or run some paracord front to back to drape blankets over to create a warmer sleeping area. They look like these:https://www.lowes.com/pd/Hillman-4-Pack-D-Ring-Large-Picture-Hangers/3029190 You'll need to open up the rearmost hole slightly to allow the Yakima nut to fit. Easy to do with a step bit. I'd recommend painting them first though as mine have surface rust on them, I guess from condensation and just temp changes.
  3. Feb 17, 2019 at 5:48 PM
    Sudsman44
    Sudsman44 Well-Known Member
    Abington PA
    2012 Tacoma Access 4x4
    Ranch cap w/ rhinorack bars, 5100s, Deaver AAL, 2” front receiver, Matt Gecko bedlights, yadda yadda…
    The deciding factor for me when I bought my shell (Ranch Sierra) is the reinforcement in the roof is 3/4” plywood, not cardboard.
