Installing vinyl lettering question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dishsoap, Jan 8, 2019.
  1. Jan 8, 2019 at 2:50 AM
    Dishsoap
    Dishsoap [OP] Well-Known Member
    White Mountains, NH
    2016 SR5 DCSB V6
    I got some vinyl tailgate lettering and it says it has to be at least 60 degrees out to do it. Has anyone done it in say 40 degree weather and had no problems? I won't see a 60 degree day for at least a few months and I don't think I can wait that long lol.
  2. Jan 8, 2019 at 3:03 AM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    Do you have a garage or know someone with one to keep the temps around the 60°
  3. Jan 8, 2019 at 3:04 AM
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    Well it’s a tailgate.... so.....
  4. Jan 8, 2019 at 3:34 AM
    Jayscull
    Jayscull Well-Known Member
    Jay
    Florida
    19 Sport
    Sounds like it’s time for a road trip!
    Dishsoap[OP] likes this.
  5. Jan 8, 2019 at 3:47 AM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    The temperature suggestion is related to the vinyl adhesion and flexibility. You can still do it, but it’s going to be more difficult. Too hot is also an issue.
    Hope that helps you.
    Comb and gurneyeagle like this.
  6. Jan 8, 2019 at 4:02 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    I found the easiest way to apply was to clean the tailgate and then spray on a mixture of soapy water (dish soap). You can then lay the lettering on and easily slide it around to get it in the right position. Pat dry then let dry. I tried one free hand without the soapy water and could not get it lined up correctly.
  7. Jan 8, 2019 at 4:29 AM
    Dishsoap
    White Mountains, NH
    2016 SR5 DCSB V6
    Duh! Why didn't I think of that lol
  8. Jan 8, 2019 at 4:31 AM
    Dishsoap
    White Mountains, NH
    2016 SR5 DCSB V6
    I don't unfortunately. But I like @YOTA 4X4 idea!
  9. Jan 8, 2019 at 4:46 AM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    and the soapy water idea...how about that one @Dishsoap
    cause, dishes in the water...Happy Tues TW!
    Dishsoap[OP] and Gator352 like this.
  10. Jan 8, 2019 at 5:16 AM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    I did my wheel decals in a 50 degree garage, the cold made it kinda easy to readjust the decal. After it was placed I hit it with my heat gun set on low. Been through a few washes and it worked fine.
    With a tailgate, I think @YOTA 4X4 is spot on.
    YOTA 4X4 likes this.
  11. Jan 8, 2019 at 5:25 AM
    ICU1
    ICU1 Well-Known Member
    Well, let’s see if Chevy’s brand new tailgate can do that.
    YOTA 4X4[QUOTED] likes this.
  12. Jan 8, 2019 at 5:25 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Fuckin' genius..... :thumbsup::thumbsup::thumbsup:
  13. Jan 8, 2019 at 6:01 AM
    jerryb1984
    jerryb1984 Well-Known Member
    Jerry
    2018 DCLB TRD OFF ROAD
    16x8 FUEL BEAST 265 75 16 FALKEN WILDPEAK AT3 Tyger step sides 20% tint front to match factory tint bilstein 5100s on third notch PRO grill
    Agree with the soapy water being used. Mine went on super easy and slid right in to place.
    Dkurtz42 likes this.
  14. Jan 8, 2019 at 6:08 AM
    Resqu2
    Resqu2 Well-Known Member
    Rick
    SW VA
    2018 Tacoma TRD Off-road
    AVS Aeroskin bug shield, TufSkinz tailgate letters, tinted windows, Undercover Ultraflex bed cover.
    I did my tufskins with a heat gun and a digital thermometer to make sure I was in the middle range that Tufskinz recommend and they worked fine. I’m sure a hair dryer would do the same but I had a heat gun with me and no hair dryer. I got the tailgate warm and then hit hit each letter just a little bit as it was a cold morning.
  15. Jan 8, 2019 at 6:10 AM
    seang
    seang Eternal Noob
    TX
    17 White Off Road
    :bowdown:
    GillyLink and YOTA 4X4[QUOTED] like this.
  16. Jan 8, 2019 at 6:14 AM
    Dkurtz42
    Dkurtz42 Bill Hwang
    David
    Barberton, OH
    2023 Tacoma DCLB TRD SPORT 4x4
    - Gator ETX Soft Roll Up Tonneau - Clazzio black leather seats - Nitto Ridge Grappler 255 80 17 tires - Supreme Suspensions 2" and 1" lift
    47 pounds
  17. Jan 8, 2019 at 6:15 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    That's just a "for best results" suggestion. I used to work for a sign shop and have installed vinyl anywhere from 10 to 100 degrees, and while it definitely works better in more moderate temps, it's still doable in almost any environment. If you're using an application fluid, it will take a little longer to dry and for the vinyl to adhere at lower temperatures. Bringing the tailgate inside is the best suggestion, and it gives you the added benefit of working on a horizontal surface.
    Big tall dave, xxTacocaTxx and NoOne like this.
  18. Jan 8, 2019 at 6:16 AM
    Dkurtz42
    Dkurtz42 Bill Hwang
    David
    Barberton, OH
    Wish I did this. It is difficult to place perfectly when dry.
  19. Jan 8, 2019 at 6:21 AM
    rickm
    rickm Well-Known Member
    Rick
    MA
    2018 BLK Tacoma TRD Pro
    I tried doing it when it was 59 degrees out and it was a complete disaster!
  20. Jan 8, 2019 at 6:26 AM
    nm4553
    nm4553 You had me at "Meat Tornado"
    Nick
    NEPA
    2017 DCSB TRD Sport
    SCS Stealth 6 Matte Bronze on Toyo Open Country 265/70R17, Fox 2.5 Coilovers, Bilstien 6150 w/ Remote Resi, Dakar Leaf Pack, Wheeler's Bumpstop, OVTuned
    Above and beyond. Props.
