Installing viper 5706V on 2015
Discussion in 'Audio & Video' started by sy272004, Nov 15, 2015.
  1. Nov 15, 2015 at 5:56 AM
    sy272004
    sy272004 [OP] Well-Known Member
    West Chester
    15 TRD V6 4x4 DC
    3" lift. 33" tires. Headlight Retro, intake, exhaust
    i looked at 5704 which is covered on here and they changed wiring on 24pin connector.
    so here id like to make how to install it on 2015 tacoma in case tacoma changed wiring as well from previous years. i cant find wiring diagram so will have to test is and try cross reference it.
    if somebody can help
    all (-)200mA output. are they go to coil on relay and then relay has to controll something else?
    here are questions so far
    24pin connector
    -200mA 2nd status/rear defogger output. i understand this is not used but i guess it can controll heated mirrors if you have them and set up relay?
    H2/1 PINK/WHITE (-) 200mA IGNITION/FLEX RELAY CONTROL OUTPUT this is not used? what does it mean flex output?
    on 5706v it doesnt have door trigger input, just has wire labeled (-) door input. im guessing we connect that diode set up to this wire?
    (-)200mA horn honk output ( can this go to factory beeper for alarm)?
    (-) 200mA ignition1 output. i dont see it being connected to anything in 5704 set up. so we just have to connect started output?
