installing windshield procedure
Discussion in '1st Gen. Tacomas (1995-2004)' started by rustedgreat, Oct 7, 2014.
  1. Oct 7, 2014 at 8:10 AM
    rustedgreat
    rustedgreat [OP] New Member
    1995 dlx v6 3.4 4x4
    "rust"
    Can anyone tell me the proper procedure for installing a windshield, the fsm that i downloaded cuts out before it says anything helpful about doing the install. Or any links to diy videos/ect would be appreciated.
  2. Oct 7, 2014 at 8:54 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Call safelite
  3. Oct 7, 2014 at 1:48 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    windshields in one thing you don't want to try doing it yourself, its well worth the cost to let a professional glass company do it.
    trust me you don't want to break it or have to deal with leak issues and they don't charge much
    I had mine done and only paid $206 total tax included that included the glass, install kit (some sort of polymer bonding agent to seal it) and the labor
    if you bring them the glass to put in it then it will probably just cost you $100
  4. Oct 17, 2014 at 10:16 PM
    all4HIM
    all4HIM Member
    VA
    '96 4x4 SR5
    I had mine replaced for $170 and they even installed a genuine Toyota for same price as generic. I wouldn't begin to attempt it for that like others said let the pros do windows !
  5. Oct 17, 2014 at 11:08 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Call insurance company, add glass coverage, doesn't cost much more, wait a week or two, call em and claim a new windshield for free:)
  6. Oct 18, 2014 at 6:43 AM
    Ktaco
    Ktaco Well-Known Member
    New Brunswick, Canada
    03 Black 4x4 TRD SR5 Xtra cab.
    Grey wire mod, Deck plate mod, diff breather mod. K&N air filter. Toytec coilovers. AAL. Custom rear lift shackles. diff drop. Centerforce clutch. Superwinch LP8500 with custom "behind bumper" mount. Winch solenoid relocation with in cab winch control. 33x12x15 Duratracs. Aisin manual hub swap.
    I replaced my own, but not the proper way. I was about 2 hours away from home at the time and just wanted something to last me for the drive back. I had a replacement windshield from a junk yard to put in. After removing the old shattered windshield I used a grinder to remove the old urethane off right to the metal, than applied a quick coat of primer. I did not have the rubber gasket to put down before installing the windshield so I just applied a healthy 1/2'' bead of urethane and put the glass in place. I put a few pieces of tape to hold the windshield in place while it dried and that was it.
    I was told the glass would crack as soon as I hit a decent bump or got flex but after 2 years it's still holding up after my Baja like trail driving. Definitely not the right way to do it but I guess all I would say is if you want to save a buck don't be scared to give it a go. When replacement time comes around again I'll probably do it myself but hopefully with the proper gasket and things.
