Installing wiring for towing
Discussion in 'Lighting' started by pikey, Mar 25, 2011.
  1. Mar 25, 2011 at 1:48 PM
    pikey
    pikey [OP] Member
    Moncton, NB
    08 Tacoma SR5
    Hi - I have an 08' SR5 Tacoma without the wiring for towing, so I picked up a harness and I just have to clip the wire harness near the bumper and replace with this one. I noticed that under the hood there is a space for a towing relay and mine is empty. So I guess that Tacomas that come wired for towing come with this relay and a dedicated harness? I should be ok to do as I plan by replaing the harness?
    Thanks!
  2. Mar 25, 2011 at 1:57 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    A good aftermarket harness will plug in-line into existing harness sockets at the tail lights.
    If yours "crimps" onto existing insulated wires , return it and get a good Toyota-specific one.
  3. Mar 25, 2011 at 2:04 PM
    pikey
    pikey [OP] Member
    Moncton, NB
    08 Tacoma SR5
    The harness does have all the wiring and sockets for the tail lights too, but I will need to cut the original harness before the splits for the taillights and towing wiring and wire in this one. It does not jus crimp to the wiring, no.
  4. Mar 27, 2011 at 5:27 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    x2....a quality harness has plugs that match your tail light harnesses - no cutting requried!
    As far as the relay is concerned, it is likely for the 7 pin connector or maybe a brake controller...I'm not sure what exactly comes with the stock towing package. However, a simple 4-pin connector doesn't need a relay because trailer lights (which nowadays are typically LEDs) don't typically draw enough current to put your stock wiring at risk. The wiring harness paperwork should speak to this fact.
