Instant "Real" Performance
Discussion in 'Performance and Tuning' started by Big O, Jan 13, 2014.
  1. Jan 13, 2014 at 3:37 PM
    Big O
    Big O [OP] Well-Known Member
    Owen
    Dallas , Texas
    ' 06 X Runner ( Red )
    K & N Air Filter , Magnaflow Muffler , Full Synthetic Oil R/P ,block,trans & differencial , New LED taillights, TRD Short Shifter, a Boulekos Sprint Booster !
    Hey Guys,
    The other day I was watching that "Motor Head" tv show & they were talking about how a lot of vehicles now don't have a hard connection between the gas petal & the carburetor. There is a sensor on the back of the petal that sends the information to the engine.
    The companies program all this in what I would call a "Safe" mode. Then the show talked about this company called, Boulekos Dynamics that makes a selectable performance part called a Sprint Booster that plugs between the petal & the OEM connector.
    There is a 3 setting button for; Off (stock), Medium (a lot of Fun), & Maximum (Full Race).
    The results are Amazing.
  2. Jan 13, 2014 at 3:39 PM
    Oowen
    Oowen Well-Known Member
    Owen
    Reno, NV
    '24 F-150
    Hello fellow Owen :wave:
    I believe URD makes something along the same lines but only for automatics
  3. Jan 13, 2014 at 3:47 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Agreed, urd does sell the sprint booster.
    Is this really a daily driver benefit tho?
  4. Jan 13, 2014 at 3:50 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  5. Jan 13, 2014 at 3:58 PM
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
  6. Jan 13, 2014 at 4:24 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Is there a possibility of having it on full race and forgetting that fact when u back out of a parking spot at full speed?
  7. Jan 13, 2014 at 4:49 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I know one guy that has one. He loves it. He says that it makes the vehicle so much more responsive. He has it on a Subaru though.
  8. Jan 13, 2014 at 4:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    All it does, is change the point at which your throttle fully opens. For example, Stock, when you apply your foot to the floor, the throttle is "WOT". The booster makes it so you can be at full throttle when you apply half throttle, or 1/4 throttle, or whatever. My thoughts are, Smashing your foot to the floor is free.
  9. Jan 13, 2014 at 4:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    In your case, I don't think so. Right now, you get tire smoke at 1/3 throttle (Im guessing), so this would allow for tire smoke at 1/4 throttle, or by simply giving it a good stare.
  10. Jan 13, 2014 at 5:38 PM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
  11. Jan 13, 2014 at 5:42 PM
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    I tend to agree. I could see how in some applications to have full WOT often and sooner in the pedal would make sense, but, that's for the closed courses.
    Still, maybe a unique to have mod for some. I like that the option is out there and being developed for the Tacoma platform.
  12. Jan 13, 2014 at 6:50 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Bahahahahhaahahha :cheers:
  13. Jan 14, 2014 at 6:13 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    The Booster not only affects the amount of throttle plate per amount of pedal push, it affects the amount of delay between the pedal movement and the throttle plate movement. So it can have a positive affect for daily driving, assuming you want quicker reaction to the petal.
  14. Jan 14, 2014 at 6:24 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Nope.
    I have one, its fun, only benefit I have found is when tuning I have a bit more throttle input.
  15. Jan 14, 2014 at 1:43 PM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Can someone can confirm that about the delay between the pedal and throttle valve opening and the fact that sprint booster correct that.
    I investigate that cause since i've installed my SC, when tuning i can see lag at pedal to medal. The truck look for 1 sec just like it will stall and you can see the AFR getting pretty rich. My only explanation was that the injectors are faster then the throttle valve and it's worst with a SC cause of the bigger injectors.
  16. Jan 15, 2014 at 8:18 AM
    Big O
    Owen
    Dallas , Texas
    That is what I am saying IT DOES. I would never start up the truck in race (red) mod first thing in the morning. It is not really comfortable to just drive around in anyway & would never do that. I start off in stock (off)with the button. But ,the middle (green) adds pep to everything after everything is warm & pumped up. As long as one is not accelerating, one can shift through all options. I like having options.
    It is doing more than just making one not have to push the petal down as far.
  17. Jan 15, 2014 at 8:42 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Just a side note... I believe that there is more travel and time lag built into the gas pedal control to make the truck easier to control over rough roads. Imagine bouncing around off road with an immediately travel sensitive gas pedal and you'll get the idea.
  18. Jan 15, 2014 at 8:53 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Like riding thru whoops on a dirt bike or landing and accidentally twisting the gas?
    I can relate.
  19. Apr 4, 2014 at 4:20 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I notice that on my new Ultraguage at full throttle in 5th gear at WOT the throttle command is 82.1%. Is this setting adjustable and/or does this device allow it to go to 100% at WOT? Oh and do they make one for the 4cyl 5 speed?
  20. Apr 4, 2014 at 5:00 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Oh yee fly by wire......
    Screwith you
