Instant "Real" Performance
Discussion in 'Performance and Tuning' started by Big O, Jan 13, 2014.
  1. Apr 4, 2014 at 5:28 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Last year I got the GMPP tune for my Solstice. Replace two sensors, take it to the dealership, they call up the mothership and reflash the ECM. After the reflash when in competitive mode (traction control off, StabiliTrak reduced) the change was huge 30 HP gain, 80 lb ft gain in torque!:eek: I wonder if this is the same sort of thing for the Tacoma? Personally I wouldn't install anything like this unless it has the TRD stamp of approval :thumbsup:
  2. Apr 4, 2014 at 9:12 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    The sprint booster?
    No
    It intercepts the input from the gas pedal and amplifies the signal so the electronic side sees a different value.
    That's it..... Takes the signal of u giving 1/4 throttle and amplifies the signal and opens the butterfly to 100%.
    That'sabout it.
    Zero HP, zero tq gain
  3. Apr 5, 2014 at 4:38 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I have old X-1 datalogs, where you can see the stock ECU had closed the throttle while the pedal position is still at 100%. Blasted nazi ECU.....
  4. Apr 5, 2014 at 6:29 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    yeah......... did a knock test the other day with torque app
    3rd, WOT..........from a roll.........82% throttle readout?!?!?!?!?
  5. Apr 5, 2014 at 8:29 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I put some chewing gum on my maf sensor and I got an instant 75 hp and 94 ft lb torque gain
  6. Apr 5, 2014 at 10:38 PM
    Oggy
    Oggy Well-Known Member
    David
    Phoenix, Az
    2010 TRD Off Road
    So basically the ziptie mod people do on sports bikes, easier to WOT but doesnt add anymore power. At least its free on my motorcycle lol.
  7. Apr 10, 2014 at 3:05 PM
    Hontseur Thots
    Hontseur Thots Member
    Sacramento
    So when the pedal is to the metal, is the fly-by-wire delivering true WOT?
  8. Apr 10, 2014 at 5:14 PM
    Spoonman
    Jamie
    Alberta
    Some cars go 100% open some don't
  9. Apr 10, 2014 at 5:35 PM
    Hontseur Thots
    Sacramento
    ...and what about Tacomas? If WOT is not actually achieved, is there performance to be gained by getting it to 100%?
  10. Dec 1, 2014 at 8:43 PM
    slickrick614
    slickrick614 Well-Known Member
    Ricky
    wanaque nj
    06 taco 2wd 5spd
    Performance clutch, aero turbine 2525 muffler, 6k hids, 5% tints, smoked tail lights
    Old post I know.....but just looked at urd.com and they have the sprint booster available for 05+tacomas auto and manual.....doesnt specify v6 or 4cyl but since it doesnt specify I would imagine it works for both or both motors use same throttle setup.....I found my next mod!!
  11. Dec 7, 2014 at 11:08 AM
    RELLIM
    RELLIM Well-Known Member
    IOWA CITY IA
    2010 ACC CAB 4X4 V6 SR5 TRD
    Scan Gauge II, AFE air filter, charcoal intake filter delete Fitch Fuel Catalyst, Alpine iDA-X303, AMS OIL (ENGINE) Bilstein 5100 RHA series
    Double tapping the gas pedal works for me. If you push it to the floor and then hit it quickly again it tricks the pcm into wot.
    why buy something that's almost 300 bucks when it gets you really no gain at all unless you have a tuner.
    What would you benefit from a larger throttle body with out tuning for it?
