Instructions or help on changing valve cover gaskets 08 Tacoma??
Discussion in 'Technical Chat' started by Techsan1, Feb 26, 2014.
  1. Feb 26, 2014 at 11:10 AM
    Techsan1
    Techsan1 [OP] Member
    Sugar Land, TX
    First Toyota product I've owned. Purchased a 2008 Double Cab 2wd 4.0 V6 a little while back has 96k miles on it. Took it to get the oil changed today at the Toyota dealership and they told the valve cover gaskets where leaking down the back of the motor and total parts and labor was 700 dollars, parts only being like 65 dollars. I've never done a gasket replacement but fairly mechanically inclined with some direction. What to torque bolts down to things like that. Looked around on here and didn't find anything for the 4.0, anyone know of a good write up? Anything else I should do while in there as preventative maintenance? Thank you in advance.
  2. Feb 26, 2014 at 4:55 PM
    Techsan1
    Sugar Land, TX
  3. Feb 27, 2014 at 7:36 AM
    rhavin42
    rhavin42 Well-Known Member
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    This might help
  4. Feb 27, 2014 at 2:32 PM
    Techsan1
    Sugar Land, TX
    Thank you for both responses. I am still trying to figure out what to torque everything down to. The diagram definitely helps.
  5. Feb 27, 2014 at 2:53 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    If your going this far, you should just go ahead and do the XTP spacer mod :thumbsup:
    Just found this:
    Torque specs,
    Upper intake 21ft-lbs,
    Valve cover, center bolts 80in-lbs, perimeter bolts 84in-lbs
  6. Feb 28, 2014 at 7:25 AM
    rhavin42
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    all the torque specs are in the document I uploaded
  7. Mar 7, 2014 at 7:02 PM
    Techsan1
    Sugar Land, TX
    I guess the dealer needed some money that day. I was told that my valve covers were leaking pretty good down the back of my motor and that my power steering and brake fluid were both black. I bought the pickup used about 8 months ago and carfax showed that it had been maintained since new at Don McGill Toyota in Katy, so I continued taking it there. My fluids were clear and not a drop of oil all the way around my valve covers. I will never return there. Ordered the parts and now feel stupid that I trusted them. Hope this information that has been gathered helps someone, and thanks for all the help.
    1Shifter and scottalot like this.
  8. Apr 25, 2016 at 11:47 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Sub'd
  9. Jul 5, 2016 at 7:00 AM
    shazaam
    shazaam New Member
    I just did my valve covers this weekend. I thought I took my time and read everything carefully .. but it looks like I got my torque values backwards. I did the center bolts 84 in/lbs and the outer 80 in/lbs :facepalm:Should this be OK? I haven't seen any leaks anywhere.
  10. Jul 5, 2016 at 2:34 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    not enough difference you could measure. I doubt your torque wrench is that accurate, in fact....
    You should be perfectly fine.
  11. Dec 10, 2017 at 9:04 PM
    hecsys_
    hecsys_ Member
    Hector
    '08 Tacoma 2WD
    1.5" front lift 0" on back (Baja style)
  12. Apr 22, 2018 at 9:33 PM
    shbop
    shbop Member
    Pacific
    08' Tacoma PreRunner
    Can someone tell me how to release the wire harness connecters on the passenger side valve cover bolts? There are two of them, and right now they're kicking my as-. Thanks in advance!
  13. Mar 21, 2019 at 2:28 PM
    Slclarry
    Slclarry New Member
    Larry
    2005 Tacoma Prerunner
    Simply pry them up off the threaded stud with a screwdriver.
