Instrument Cluster Calibration ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yota Bird, Oct 16, 2014.
  1. Oct 16, 2014 at 7:56 AM
    Yota Bird
    Yota Bird [OP] Active Member
    Johnathan
    North Carolina
    99 White Prerunner 2.7L
    6K HIDs,6K LED Foglights,Magna Flow Hi-Flo Cat,Flowmaster 40,Tinted Brake Lights,Clear Corner and Turn Light Housings
    Im planing on replacing my current cracked instrument cluster with one I found at a junkyard, I had the digital odometer so does it need to be calibrated or flashed so I can use it one my truck or is it just plug and play ?
  2. Oct 16, 2014 at 10:09 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    if it's the same model truck and engine then it should be plug and play
  3. Oct 17, 2014 at 6:51 AM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    If your truck is a 4cyl and automatic, then the truck you are pulling it from needs to be the same drivetrain setup.
  4. Oct 17, 2014 at 8:32 AM
    Yota Bird
    Johnathan
    North Carolina
  5. Oct 18, 2014 at 6:49 AM
    offrdmania
    Templeton, Ca
    Correct, a 5 speed cluster doesnt have the right calibration and also doesnt have the automatic gear indicator lights. An automatic cluster will have the P, R, N, D, 2, 1 vertically between the speedo and tach gauge
  6. Oct 20, 2014 at 6:44 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I know on my 85' if I wanted to use a tach from a v6 I had to adjust the sensor behind the tach. Real easy to do with a screwdriver. Just hook up a dwell or Ultra Gauge or something to read the true RPM's and adjust accordingly by turning left or right.
  7. Oct 20, 2014 at 2:06 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    if you have the floor shift then I think this is what you need: http://www.ebay.com/itm/98-99-00-To...Parts_Accessories&hash=item35d76564cd&vxp=mtr
    if you have column shifter then you need the one with the shift lights down the center between the tach and speedo
    when you find one it might have more miles then you like or even less then yours does, I don't know if you can change that part of the cluster out with yours or recalibrate it but you might have to live with whatever the new one says.
    whats wrong with your old one?
  8. Oct 20, 2014 at 3:02 PM
    offrdmania
    Templeton, Ca
    Every state is different when it comes to mileage. I am in California and all that they care about is that it shows the correct mileage so I was able to swap my old mileage tumbler into the new cluster. Check with your local DMV to verify what is legal in your state
  9. Oct 20, 2014 at 5:10 PM
    Yota Bird
    Johnathan
    North Carolina
    Well the only thing that is wrong with mine is the clear plastic part is missing, Do you know if there's somewhere I can get one ? At least I think that part is replaceable
  10. Oct 20, 2014 at 6:18 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Good luck finding that piece, I just replaced the whole thing didn't effect my mileage at all
  11. Oct 21, 2014 at 6:59 AM
    keakar
    karl
    louisiana
    well then any similar gage cluster will work then because the clear covers are all the same weather manual or auto so get a cheap one just for the clear cover to use on yours.
    how in the hell did you break yours? must be a hell of a story :confused:
  12. Oct 21, 2014 at 3:07 PM
    Yota Bird
    Johnathan
    North Carolina
    It was cracked in half when I got it and it would rattle really bad so I just finish breaking it lol :D
  13. Oct 21, 2014 at 3:11 PM
    keakar
    karl
    louisiana
    darn, I was hoping it involved a battle with space aliens or hot chicks with big hooters :cool:
    good luck, hope you can find a good deal and ask in the for sale section if anyone has a broken one that isn't cracked
