Instrument Cluster Change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by keninsb, Oct 23, 2013.
  1. Oct 23, 2013 at 6:30 PM
    keninsb
    keninsb [OP] "Senior", Senior Member
    Ken
    Goleta, CA
    '13 Taco DC 4WD V6 LTD
    I recently stepped down from a Tundra to a 2013 Tacoma LTD. I cannot believe how "limited" it really is! No oil pressure gauge, no info center, no rear disc brakes and on and on. Those are things that I thought would come standard on most 2013 Toyotas especially a LTD.
    Anyway, I was wondering if anyone has done a cluster swap out? Does the 4Runner have oil pressure gauge and is it possible to swap out a 4Runner cluster for a Tacoma cluster? Any input greatly appreciated.
    Thanks,
    Ken
  2. Oct 23, 2013 at 7:53 PM
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    Not that I have seen. A lot of people that need extra gauges use pods on the steering wheel or on the pillar. You could also use a Scangauge or Ultragauge.
  3. Oct 23, 2013 at 9:30 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You didn't look at the Tacoma before you " Stepped Down "?
  4. Oct 23, 2013 at 9:31 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    4 Runner dash is totally different... and it doesn't have OP either.
    There are no factory options for anything other than speed, tach, fuel, and temp.
  5. Oct 24, 2013 at 10:59 AM
    keninsb
    Ken
    Goleta, CA
    Oh yeah, and I would not have purchased the truck "blindly", but there are more and more things I am finding that I expected to be factory. I have owned Toyotas for the last 25 years, and the first truck I bought back in the '80s even had an oil pressure gauge.
    '90 Tacoma Cluster:
    It just seems like Toyota has cut a lot of corners over the years.
    When I had the Tundra I bought an "Optitron" cluster (the type used in the LTD models) and installed it in my SR5. The cluster itself looked a lot nicer, but once installed it added a LOT more information available to the driver (average mileage, real time MPG, average speed, etc.) and functionality (adjustments for door locks, seat belt chime, etc.). I was just wondering if there was a similar mod for the Taco.
    Ken
  6. Oct 24, 2013 at 11:26 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Well you did buy a "limited". It's just not limited on chrome. Chrome everywhere!!!
  7. Oct 24, 2013 at 12:50 PM
    keninsb
    Ken
    Goleta, CA
    Not anymore...
