Instrument Cluster/Dash lights all out. Any ideas?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tyler Andrews, Feb 23, 2013.
  1. Feb 23, 2013 at 6:24 PM
    Tyler Andrews
    Tyler Andrews [OP] Well-Known Member
    Tyler
    Portland
    2018 Super White Sport 4x4
    I drive a 2003 toyota tacoma xtra-cab. I recently purchased the truck, and sadly sound out that none of the dash lights work(needle,gas,mpg,fuel,oil, etc.) I have checked some of the fuses, but could not find any brocken. I just think it's odd that all the lights are out at once, seems more like a fuse issue than bulb.
  2. Feb 26, 2013 at 2:13 PM
    Tyler Andrews
    Tyler
    Portland
    ANYONE????
  3. Feb 26, 2013 at 4:25 PM
    raghorn
    raghorn Member
    ms
    2003 taco
    10amp fuse under the hood.................
  4. Feb 26, 2013 at 4:56 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Did you check all the fuses? ^is the instrument panel fuse under the hood? Start with locating the combination meter fuse.
  5. Feb 26, 2013 at 7:02 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Check your fuse then check all the wires because something had to happen to blow the fuse, my dash fuse would blow as soon as I turned my lights on ended up being a short behind the radio
  6. Feb 26, 2013 at 8:15 PM
    wesb1023
    wesb1023 Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    Umm, also check the reostat setting on the dash... I have worked on a few vehicles in the past and that was all that was wrong when they brought it in.
  7. Feb 27, 2013 at 12:40 PM
    Tyler Andrews
    Tyler
    Portland
    What is the reostat setting wesb1023
  8. Feb 27, 2013 at 3:18 PM
    jkirkpatrick
    jkirkpatrick Well-Known Member
    Edmonton
    2018 4Runner TRD Offroad edition (2000 Tacoma sold in 2018)
    Lift, tires, wheels, bumper, winch, sliders, skids, regeared
    Not to be a douche, but the dash light dimmer isn't turned all the way off, is it? :eek:
  9. Feb 27, 2013 at 6:20 PM
    Tyler Andrews
    Tyler
    Portland
    haha no that was definitely the first thing i checked! but thanks for the input
  10. Feb 27, 2013 at 6:25 PM
    cbassd
    cbassd Member
    sebastian
    Nor cal Davis
    02 tacoma
    tc uca, 2.5 icon coilovers with resis, trd supercharger,flow master,u-bolt flip kit,,, all-pro standard pack leaf springs,10 inch travel 2.0 fox shocks with remote resis,21inch led bar,ham and cb radio,4xinnovation sliders, custom from bumper, prp bucket seats and deist 5-point harness
    Haha man that would have been so funny if it was :D
  11. Feb 27, 2013 at 8:06 PM
    wesb1023
    Westley
    Eastern NC
    04 Double Cab
    Reostat = dimmer switch....
  12. Feb 27, 2013 at 8:09 PM
    wesb1023
    Westley
    Eastern NC
    04 Double Cab
    Also, are the lights in the radio and everywhere else working? I had my dash apart today and noticed that if the dimmer switch was not plugged in, nothing would work. So, if its not turned all the way down, it still could be faulty.
  13. Mar 18, 2013 at 12:30 AM
    Psyclic85
    Psyclic85 Zombie Killer
    Arizona
    04 Ext. Cab Tacoma 2WD
    Deck Plate MOD, Billet Grille, LYNEX bed liner, Clear corners, Blacked out tail lights
    I too am having a very similar problem at the moment! Installed a new in dash DVD touch screen in my 04 Taco and as soon as I went to turn on my head lights, i heard a little pop and all my dash lights went out... (Found the ACC 10a fuse popped and replaced it with new 10a fuse.) I have been struggling now for the last 2-3 days trying to get this dang dvd player to work and also trying to get my dash lights to come back on but no luck!
    After fighting with this new DVD player I decided to put my stock stereo back in PRAYING this would fix everything but nope!! Still no dash lights. The headlights and all exterior lights still work normal but when i turn on the head lights, the dash lights should come on but they are not! So now my truck is fully back to its original form with harnesses and all connected again correctly but having issues.
    For obvious reasons I checked the basics... dimmer switch isnt all the way turned off, checked every single fuse in the fuse panel inside the truck as well as under the hood, no blown fuses. Even the lights that illuminate the letters/numbers on the shifter are out.
    PLEASE HELP!!
  14. Mar 18, 2013 at 8:52 AM
    Nunavut
    Nunavut Eh oh, Canada go.
    Canada
    Is the stereo grounded?
  15. Mar 18, 2013 at 9:38 AM
    Geosh
    Geosh Why yes, I AM a rocket scientist.
    Chandler, AZ
    '03 PreRunner DC, 3.4L
    Use a multimeter and check for voltage at the dimmer switch harness. Did you hook up the illumination wire on the new deck when you installed it? If so, did you check if you hooked it up to a positive or negative polarity dimmer on the truck harness? If you got it wrong, it could have fried something.
    Once we know the dimmer is passing voltage, then you can move on from there. If you have no power to the dimmer, re-check your fuses. If you have power in, but no power out, then it is a dimmer issue. If you have power in and out, but no lights... then... well...
  16. Mar 18, 2013 at 10:30 AM
    Psyclic85
    Arizona
    I will check the dimmer switch harness, this may sound dumb but how do I remove the dimmer switch. Im hoping I didnt fry something. I did hook up the illumination wire to the new deck to the illumination wire from the truck. Thats all it was connected to.
  17. Mar 18, 2013 at 10:45 AM
    Geosh
    Chandler, AZ
    You might be able to get to it by dropping the dash panel under the steering column. I just had mine apart last night but can't remember if you will have to pull the bezel too. Do a search for "dash light replacement" and there are a couple posts that show how to get the bezel off if you need to.
  18. Mar 18, 2013 at 6:17 PM
    Psyclic85
    Arizona
    Thanks!
  19. Aug 2, 2014 at 3:20 PM
    dncstrever
    dncstrever New Member
    RAGHORN is correct….at least for me. It was a blown 10 amp fuse under the hood identified as taillight… Thanks
  20. Mar 28, 2016 at 11:09 AM
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    bumping this thread since I had a similar issue. Installed a set of otrattw switches and tapped into the green/green-white switch illumination wire. After doing the install, none of my switches (factory and add ons) illuminated and even my factory entune head unit no longer dimmed when the headlights were turned on.
    I eventually found the busted fuse and it was in the fuse panel under the dash marked "tail" (10A fuse).
