Instrument cluster dash lights not working
Discussion in 'Lighting' started by Joe02TRD, Oct 15, 2011.
  1. Oct 15, 2011 at 5:01 PM
    Joe02TRD
    Joe02TRD [OP] Well-Known Member
    Joe
    Woodbridge, CT
    4cyl 5sp 4x4 SR5 TRD
    Need help....Just picked up my 02 Tacoma last week, dash lights do not come on. I've checked both fuses and they're both good, pulled the cluster out and put in new 194 bulbs in place of the stock ones with the orange covers and still no luck. My hvac and radio lights come on and dim with the switch and every other light works except the dash lights at night. Any ideas?
  2. Oct 15, 2011 at 5:03 PM
    JAG
    JAG Well-Known Member
    after market radio?
  3. Oct 15, 2011 at 5:10 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Try another Headlight switch.
  4. Oct 15, 2011 at 5:59 PM
    Joe02TRD
    Joe
    Woodbridge, CT
    stock radio and everything else works, every single light except 4 dash illumination bulbs so the switch seems to be working..?
  5. Oct 15, 2011 at 6:08 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Sounds right to me.
    You need to make sure you have power at the connector to the instrument cluster. Sounds like a possible open wire.
  6. Oct 15, 2011 at 6:17 PM
    Joe02TRD
    Joe
    Woodbridge, CT
    I just printed the service manual wiring diagram for the cluster, I'm going to pull it out again tomorrow. Anyone know what the "bulb check relay" shown on the cluster is/does or how to test it?
  7. Oct 15, 2011 at 6:28 PM
    JAG
    i know this may sound crazy... but being careful not to break anything... give the face of the gauges a couple solid tap with your fingers (light but firm)... see if any lights flicker or change.
  8. Oct 15, 2011 at 6:33 PM
    Joe02TRD
    Joe
    Woodbridge, CT
    haha ... will do tomorrow
  9. Oct 15, 2011 at 6:35 PM
    NelsonTacoma
    Tucson, AZ
    That is actually good advice. I test a lot of electrical parts on cars that way. It's what we call "the good ol tap test" at the shop I work in.
  10. Oct 15, 2011 at 6:44 PM
    Joe02TRD
    Joe
    Woodbridge, CT
    thanks guys, I appreciate the help. I plan on digging into it tomorrow.
  11. May 17, 2013 at 5:26 PM
    curious one
    curious one New Member
    I'm having the exact same problem with my 'new' '02 Tacoma. Did you ever find a solution?
  12. May 17, 2013 at 5:29 PM
    Recker
    Recker Well-Known Member
    Recker
    Indiana
    07 Tacoma 4x4 Indigo Ink Pearl
    Needs whoring LOL
    Me too! In my 07, there is an aftermarket stereo.... Fuses are all good, I've been too chicken to take the dash apart LOL
    Linda
  13. May 17, 2013 at 9:28 PM
    curious one
    Well, my solution turned out to be pretty simple; the bulbs were bad. All of them. I figured the chances of them all going bad simultaneously was pretty slim, so I thought there must be a bad ground or something. Maybe the previous owner drove around watching them go out one by one, then traded it in for something else :D
  14. May 17, 2013 at 9:36 PM
    Recker
    Recker
    Indiana
    Needs whoring LOL
    Humm I'll have to check that out. I figured like you, chances were slim that all the lights would be bad. Maybe it would be a good time to do one of those awesome dash light mods!! I'll report back when I figure mine out. Thanks!
    Linda
  15. Feb 28, 2015 at 9:09 AM
    Fletcher Aspden
    Fletcher Aspden Member
    Fletcher
    Florida
    2003 tacoma 4x4 and a 4x2
    Everything you can do right down to a supercharger.
    I just got another 03 tacoma and the dash Gage lights didn't work but everything else did.. Checked all the fuses and the dimmer first as all of us do. You wouldn't think that all the dack lighting could be blown at the same time but if it's a used truck and you dont know the history of it than it is possible.. I looked and checked everything but as it turns out I pulled the dash and all four bulbs wer out ..get four 194 white bulbs at the auto parts store , take it apart.. ( it's not that hard ) the bulbs are in a quarter turn green plug on the back of the gage cluster and they have a orange little rubber over the bulb that you reuse . Sometimes it is that simple..cost $8 .. After all a toyota is the best thing on the road...
  16. Feb 22, 2023 at 6:55 PM
    Bjc2002Tacoma
    Bjc2002Tacoma New Member
    Bradley
    2002 Tacoma Xtra Cab 4X4
    Custom Front Bumper and Winch
    I have a 2002 Tacoma extra cab four-wheel-drive four-cylinder, and after towing a trailer, where all of the lights worked just fine, all the sudden my dash lights quit, turns out it’s the number 10 tail light fuse under your hood in that fuse box.
  17. Apr 8, 2023 at 11:52 AM
    Yourmomx1
    Yourmomx1 New Member
    Just replaced all my dash cluster lights now none work. I have no park lights or anything. All fuses are good. What the heck?
  18. May 27, 2024 at 10:39 AM
    Bobs02T
    Bobs02T New Member
    Tacowner
    Did you ever figure out what happe3ned to the lights? I have the same problem.
