instrument lights not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by brycewchilds, Aug 27, 2009.
  1. Aug 27, 2009 at 7:01 PM
    brycewchilds
    brycewchilds [OP] New Member
    04 4x4 dbl cab
    I've got an 04 taco dbl cab 4x4. My instrument lights quit coming on. The switch is on and the knob that adjusts the light intensity is all the way up. Any ideas? I don't even know how to begin diagnosis.
  2. Aug 27, 2009 at 7:06 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    I don't know about the 04's, but on my 06, If you go all the way up on the intensity it shuts off. Pull it back just a little and it is at highest setting. Hope that's all it is. :confused:
  3. Aug 27, 2009 at 7:17 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Check the fuses under the dash??
  4. Aug 27, 2009 at 7:21 PM
    t33gee
    t33gee aka Tg
    Tyler
    Riverside, CA
    03 prerunner
    k and n CAI, magnaflow exhaust, NOS
    fuse?
  5. Aug 28, 2009 at 6:17 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Is it only the lights in the instrument cluster, or all the dash lights, that don't work?
  6. Aug 28, 2009 at 9:03 AM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    Check fuses, check your cig lighter outlet wires ( yes this can cause them to go out, it happened to me ) Did you have an aftermarket radio? If so check those wires.
  7. Aug 28, 2009 at 9:36 AM
    brycewchilds
    04 4x4 dbl cab
    Ok I've tried moving the dial but no good. I'll check fuses tonight. It is all of the lights on the dash. Stereo AC heat controls. Everything. The lights for 4x4, diff lock, OD Off lights come on still. I've not got an aftermarket stereo. The truck is completly stock. I'll check the cigarette lighter wires.
  8. Aug 28, 2009 at 11:57 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    It's not just a fuse, and it's not just a bad ground. If it were - *ALL* the lights would be 'out', and the ones you mentioned as still working wouldn't be working ...
  9. Aug 28, 2009 at 12:08 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    trailer wiring harness. it's behind your left tail light
  10. Aug 28, 2009 at 12:27 PM
    98tacoma27
    Ben
    Not Beech Creek
    x2 or the tail light fuse
  11. Aug 28, 2009 at 1:17 PM
    brycewchilds
    04 4x4 dbl cab
    Ok and what am I supposed to look for
  12. Aug 28, 2009 at 3:01 PM
    98tacoma27
    Ben
    Not Beech Creek
    The junction of the wires with the light wiring. Look for a loose connection, frayed/damaged wire or a loose ground wire.
  13. Aug 29, 2009 at 1:11 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    Not quite, there will be a black box with 5 wires running in and 4 wires running out (or vice versa not completely sure)
    the box is completely sealed, I couldn't get into it even after taking it off. your going to need a new one, which is about $14 dollars from any auto parts store.
    this is going to be the issue if you keep blowing the dome light fuse which will kill your tail lights and instrument cluster too.
    best of luck
  14. Sep 12, 2009 at 7:34 PM
    slickyd
    slickyd Well-Known Member
    David
    Talladega, AL
    03 PreRunner SR5
    i had the same problem when i first got my truck. There is some kind of short or something behind the cluster. If you hit the top of the dash right above it it should come back on in a 2 or 3 hits. They have been staying on ever since i did that 8 months ago. Give it a try it wont hurt anything
  15. Sep 13, 2009 at 1:10 PM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    no dash lights? did you check the tail lights? usually they are linked to let you know you have a problem
  16. Sep 13, 2009 at 9:37 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    hey man did you ever figure it out?
  17. Sep 13, 2009 at 10:48 PM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    hey brycewchilds any updates? Are they still out?
