instrument lights went out
Discussion in '1st Gen. Tacomas (1995-2004)' started by jake22si, Mar 4, 2023.
  1. Mar 4, 2023 at 8:32 AM
    jake22si
    jake22si [OP] Member
    Just figuring this truck out only had it for a week. 95 tacoma 4x4 v6 auto. Cluster lights worked but not the heater controls lights or the gear selector light. I opened up the shifter console and twisted the connector out and the bulb lit up a few times and then went out. It was after that I noticed the cluster lights were out now. gauge fuse is good. Ill check for power when I have more time, and the rheostat is not dimmed.
  2. Mar 4, 2023 at 8:50 AM
    jake22si
    tail lights, license plate lights, horn and hazards all work
  3. Mar 4, 2023 at 10:04 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I would try bypassing the rheostat or testing it.
    Bivouac likes this.
  4. Mar 4, 2023 at 1:33 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    X2 on check the rheostat
    Also check for a poor ground and loose connections.
  5. Mar 4, 2023 at 2:01 PM
    jake22si
    Reached up in there and unplugged the rheostat, plugged it back in and nothing.
    The gauge fuse was good, but that’s not the fuse for the “panel” lights, that’s under the hood. Doh
    All fixed now and have heater and gear lights.
    Bivouac likes this.
  6. Mar 4, 2023 at 4:08 PM
    rkilpa
    rkilpa Active Member
    Ron
    2001 Tacoma SR5 Double Cab
    Is it possible that you had only one working dash bulb and it just went out like the rest already did? There are four type 194 bulbs that illuminate the instrument panel. They are most likely burnt out after 28 years. The same goes for the bulbs behind the climate control, gear shift indicator, ashtray and glove box. They are probably all bad by now.
    I needed to replace every bulb on my dashboard when I bought my truck because only 3 bulbs total still worked.
