Insulate the garage walls - or not?
Discussion in 'Garage / Workshop' started by jsi, Oct 16, 2018.
  1. Oct 17, 2018 at 9:45 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    $70 an outlet, got dang.
    honda50r likes this.
  2. Oct 17, 2018 at 9:48 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Add a half hot (to a light switch) in your master vanity underneath. Then you can run a led strip and a Lutron occupancy sensor, it'll light up when you walk in the bathroom. Super nice in the middle of the night. It'll only cost you a portion of what the builder will charge for under cabinet lighting. You can use the other part if the outlet to connect your electric toothbrush, then it's not sitting on the counter. That's what I did also.
    jsi[QUOTED][OP] likes this.
  3. Oct 17, 2018 at 10:05 AM
    blackoutt
    blackoutt @blackoutt_adv
    Southern IN
    INSULATE now instead of worrying about it later.
    I just moved all my tools from my detached garage to my attached garage for this reason. That uninsulated detached was hot in the summer and cold in the winter. Attached insulated garage (with insulated door) while not perfectly workable at all temps is much more comfortable.
    doublethebass likes this.
  4. Oct 17, 2018 at 10:30 AM
    CorpsTaco
    CorpsTaco Well-Known Member
    2018 OR DCLB
    For just insulating the walls I would do it yourself as long as you have the cash to do it right away. You’ll 100% end up wanting it insulated. In Michigan winters without insulation in the garage walls the water from snow melting off the vehicles would freeze on the floor overnight, but does not now that we’ve insulated it. I did ours myself, but that was the easy part. I would be more concerned about whether you plan to run more wiring/outlets after the fact and what comes after insulation.
    We built ours a few years ago and if I could do it all over again, I would have had the builder finish down to sanded mud, all of the walls they’re required to finish to meet code. Then I would have insulted and put up OSB on the remaining walls and let it be. We did drywall and paint ourselves and because I’m no good at mudding/sanding it looks like a bag of ass. Painted OSB would look and function much better.
    Also, definitely run 20A wiring in the garage. If the wife doesn’t understand it, tell her that she won’t be able to run more than 1 crockpot in the garage at a time for parties and she’ll make the decision for you haha.
  5. Oct 17, 2018 at 10:37 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Should you insulate the garage?
    Absolutely. That should never be a question.
    Should you pay the builder to do it?
    Absolutely not.
    At least 99% of the time builders use the cheapest materials they can find and charge as much as they can get away with.
    I would compare the price of the builder doing it vs. you doing it yourself.
    If you do it yourself chances are you will save a boat load but also get much better quality insulation.
    In addition I would plan on blowing in about 12-18” of insulation in any open attic space above the garage. It really helps with temp control. Just doing the walls only goes so far.
  6. Oct 17, 2018 at 10:45 AM
    CorpsTaco
    2018 OR DCLB
    I agree and would like to add one note for the OP.
    If you need insulation in the garage ceiling and plan to hire someone else to do it eventually (not doing that part yourself), I would have the contractor do that when the rest of the house is done. Materials are not too pricey unless you’re going fiberglass, but to have a crew show up after the fact they will charge you a minimum just to show up with the machine and then labor on top of that. Atleast what’s what we found out in our area.
  7. Oct 17, 2018 at 10:50 AM
    okichewy1
    okichewy1 Just chuggin' along!
    Ken
    Kimberly, Idaho
    2018 DCSB TRD Sport Quicksand
    Ultra Flex bed cover, TRD PRO Grille, 32" LED light under grille, Pop n' Lock on tailgate, OCD organizer for center console and glove box, LED bed lights, OEM bed mat, black TACOMA tailgate letters, LED illumination light package, black vinyl overlays for badges, OEM bed step, plasti-dipped front valance and mirrors, 15% tinted windows and sun strip, vinyl letters on dash, vinyl letters on tailgate handle and door sill protectors, TRD Pro shift knob, home-link rear view mirror, mountain vinyl decal above Tacoma on door, FN FX pro wheels, AVS bug deflector, AVS in-channel window vents, front bed rail, red line hood struts, LED interior lights, TRD Pro skid plate, slim line front license plate holder, CaliRaised LED Ditch light brackets with LED lights, Bilstein 5100's, OME 888's, Dakar HD leaf springs, cubby covers, CaliRaised LED Fog light kit,
    If it's cold where you are and you work out there through the cold months, get it insulated, get the insulated garage doors and have them install at least a 240v outlet for a ceiling heater and don't let them just install 1 bulb fixture in the ceiling. Make sure you get some say in how the lighting in the garage is going to go.
    toyotatacomaTRD likes this.
  8. Oct 17, 2018 at 11:17 AM
    toyotatacomaTRD
    Also, put a drain in the garage floor. Then you can squeegee all the water that comes off you car's right to it. We gets lots of snow, so it turns into a lot of water.
  9. Oct 18, 2018 at 11:26 PM
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    I did the walls but not the attic space. In the long hot So Cal summers my garage does not get near as hot but it works both ways. Now unless I open the garage door it stays too warm all night. I added a solar gable fan to help blow in cooler air from down low and have a portable AC that really helps.
    I had an electrician buddy help me run 20 amp plugs, LED lights and two 240V outlets on a separate breaker box years ago. Best thing I could have done. I ran the conduit, installed the boxes, pulled the wires and he came and hooked it all up.
  10. Jan 10, 2019 at 8:00 AM
    jsi
    jsi [OP] Well-Known Member
    native earthling
    I'm going to turn this into a build page, cause why not? The house will have an insulated garage, yeah! Here's the videos I've made so far.
