intake and exhaust question
Discussion in 'Performance and Tuning' started by krisjw101, Jan 27, 2009.
  1. Jan 27, 2009 at 10:25 PM
    krisjw101
    krisjw101 [OP] Well-Known Member
    Kris
    Spokane,WA
    09 Tacoma 4x4
    Autobot in my rear window
    if i were to buy a k&n intake and a new exhaust and put them on my 09 tacoma would that cause warrenty issues or void it? i'm not sure, does anyone know?
    thanks
    kris
  2. Jan 28, 2009 at 5:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No. You will be fine.
  3. Jan 28, 2009 at 8:18 AM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    As chris said.. you'll be fine. You are protected by the Magnuson-Moss warranty act.
  4. Jan 28, 2009 at 8:28 AM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    Adding even a TRD cold air intake does void your warranty
  5. Jan 28, 2009 at 8:41 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Huh? It does? :confused:
  6. Jan 28, 2009 at 8:46 AM
    Blackened Taco
    Tony
    Virginia
    Yeah even adding a TRD intake voids the warranty, on the outside of the box in BIG letters it says so. You can't even open the box without seeing the notice. I still put it on my truck, just DO NOT over oil the air filter and you will be fine. Over oiling the air filter will short out your mass air flow sensor.
  7. Jan 28, 2009 at 8:51 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Oh okay got yah! Now what about an aftermarket cat-back exhaust system? Does that void the warranty as well? Because I heard it doesn't.
  8. Jan 28, 2009 at 8:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It voids the original warranty on the intake. Magnuson-Moss warranty act stipulates that the manufacture has to prove that the part in question caused whatever problem goes to light. The TRD intake is for "off road use" only, as it removes the charcoal filter, thus possibly voiding any emision warranty, and makeing it not legal for street use in some states.
  9. Jan 28, 2009 at 8:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    no cat-back exhaust system voids the warranty.
  10. Jan 28, 2009 at 9:04 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    No.. Incorrect.
    Yes.. Correct.
    By law a dealership cannot void/cancel you warranty because aftermarket parts are installed on your vehicle. They have to prove without question that the aftermarket part caused the item under question to fail.
    http://en.wikipedia.org/wiki/Magnuson-Moss_Warranty_Act
  11. Jan 28, 2009 at 1:35 PM
    Blackened Taco
    Tony
    Virginia
    Putting on an exhaust will not void your warranty, as for the intake it will only void items that are directly related to a compponent failure casued by the aftermrket parts
