intake and exhaust suggestions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kaptin_kevin, Mar 26, 2016.
  1. Mar 26, 2016 at 11:11 PM
    kaptin_kevin
    kaptin_kevin [OP] Member
    Kevin
    2013 Tacoma Trd Sport
    Stock for now
    Need help on choosing an exhaust and intake. Any suggestions??
  2. Mar 26, 2016 at 11:12 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
