Intake chamber gasket
Discussion in '1st Gen. Tacomas (1995-2004)' started by choopes, Sep 7, 2022.
  1. Sep 7, 2022 at 2:59 PM
    choopes
    choopes [OP] Well-Known Member
    Troy, Al.
    2004 reg cab
    Stock
    I am putting the engine back together on my 2004 Tacoma w/ 2.4 engine. I removed the Intake chamber. Should I replace the gasket? Its $28 at O'Rilley's.
    Truck has 177k at the time of engine removal and re-install.
  2. Sep 7, 2022 at 3:32 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    You should replace it.
    Edit: To provide some rationale for this- When I replaced my valve cover gaskets (albeit from my v6) the OEM metal gaskets had a coating over them which when distributed (from removal) flaked off in places creating an uneven seal surface.
    I wouldn't suggest that you replace the gaskets if they were like a year old and didn't show signs of an uneven surface, but given the age and miles, $28 bucks isn't terrible.
    Nessal likes this.
  3. Sep 7, 2022 at 4:49 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I separated the two pieces.....to clean egr passage out.....and I bought the felpro kit with both gaskets...
    about 6mo ago.....$28 sure seems high....
    The felpro were metal
    Looked at old one....and that was the middle cool one.....and its coating is delaminating/peeling....
  4. Sep 8, 2022 at 8:07 AM
    choopes
    Troy, Al.
    2004 reg cab
    Stock
    It does seem high. And difficult to find. Unless I want to order a complete gasket set, I don't need that. I will get the $28 one from Orielly's, not cheap but fast. I want to get this one together, with no air leaks on my intake!
  5. Sep 8, 2022 at 8:16 AM
    O'Silver_Taco
    MD
    choopes[OP] likes this.
