Intake/Exhaust ARE THEY WORTH IT ??????
Discussion in 'Performance and Tuning' started by 2010TRD, Mar 23, 2012.
  1. Mar 23, 2012 at 9:59 AM
    2010TRD
    2010TRD [OP] Well-Known Member
    Thomas
    Waldo, FL
    2010 MGM trd offroad DCSB
    Billistein 5100 front/rears, Toytec 2" AAL Custom grill, All Pro rear bumper, All Pro sliders, Anytime elocker/foglights, Rear diff vent relocated, W/O seat covers, weathertech mats/visors, nfab tire racK, cobra 75 stealth CB, Custom engine/trans skids 3/8", Hella and HID behind grill, LED bar backup light, LED pods under cab (rocklights)
    from what Im reading everywhere....... The CAI doesnt do much for performance, and is usually loud.......
    I prefer to gain HP without compromising my quite smooth ride......
    Ive had the loud straight pipe exhaust trucks in my past (high school) when it was "cool" to be loud.......
    I go on road trips, and think the constant sound of intake/exhaust would annoy the hell out of me.
    opinions on this??????
  2. Mar 23, 2012 at 10:02 AM
    Cowboyz
    Cowboyz Membor
    Luke
    Southern Utah/Las Vegas
    07 DC LB TRD Sport
    6in Pro Comp stage 2 lift, 2.75in ProComp Coilovers, Rear MX6 adjustable shocks, 35in Nittro Trail Grapplers, 17 in XD Spys, URD intake, URD MAF Calibrator, Flowmaster 40 Series, AMP Power steps, debadged, blacked out tail lights, Blacked out headlights w/ Mini H1 Retros and halos, JVC KW-AVX840 7" Double-Din, Viper 5704 2way alarm/remote start, LEDs in Dome, Maps, and license plate lights, short black antenna, 5% Tint, removed sway bar
    The URD True Cold air intake is dyno tested to give more HP. and it helps that the filter is up in front of the radiator for the noise.
  3. Mar 23, 2012 at 10:04 AM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    save your money, keep it stock.. you wont gain any horse power worth a damn like 5 hp tops unless you go supercharged.
  4. Mar 23, 2012 at 10:08 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Spend the money on armor for your truck better invest ment
  5. Mar 23, 2012 at 10:11 AM
    2010TRD
    Thomas
    Waldo, FL
    I think im gonna keep performance at the stock level......of course a K&N drop in has already been done.
    Spend the money saved on a 6" lifter..........
    Agree?
  6. Mar 23, 2012 at 10:17 AM
    2010TRD
    Thomas
    Waldo, FL
    well now the lift kit is totally different subject......
    What size tires can I fit under a 3" lift??
  7. Mar 23, 2012 at 10:21 AM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SP... CaL
    11 TRD sPort
    5100's@1.75 Horns (Andres) Satoshi TRD cat back BHLM
    33'' tires with slight trimming
  8. Mar 23, 2012 at 11:19 AM
    2010TRD
    Thomas
    Waldo, FL
    thanks for the link.....good info on there.
    Thanks all for your input.....
    Decided to stay stock, due to most of my offorading being in wet/muddy conditions with water crossings........
    May add a magnaflow muffler in place of stock can....but that would be it.....
  9. Mar 23, 2012 at 3:31 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    You have dyno proof to back up said claim?
  10. Mar 23, 2012 at 3:38 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    Extra fog lights behind grill, Pro Form rubberized undercoat, Fog lights on w/ high beams mod, Lighted 4wd switch, Husky Liners, 12v always on, Yellow wire mod, DEVIL HORNS BABY!! OME 886's Nitrochargers w/ 1.5" AAL with 1" lift block, Redline hood struts, front/rear winch wiring, Blue Sea systems Fuse Block, Spidertrax spacers, Wet Okle seat covers, ECGS front diff Bering Replacement Are LR UCA's right for me???
    I'm sure all of the major manufacturers have a dyno chart showing peak hp gains. And on a small engine (4L) those gains won't be excessive.
  11. Mar 23, 2012 at 4:49 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Your engines computer is not designed for aftermarket items that *make horsepower* so unless you retune your ECU you wont see gains higher than say 5 HP.. simple as that they will make lots of noise and sound cool but your fuel air mix is still going to remain the same.:cool:
    but hey if your butt dyno is saying otherwise who are we to judge.......
  12. Mar 23, 2012 at 4:54 PM
    Manwithoutaplan
    ID
    no.. dont waste your money.
  13. Mar 23, 2012 at 5:00 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Ok so add up all the things you want to complete your cheap aftermarket horsepower build:
    Intake: $250-$350
    Headers: $700
    Exhaust: $250-400
    URD calibrator: $200
    Total for maybe 10-20 HP $1500+labor
    Supercharger:$4000+labor for 75-120 horsepower.
    Total kit you would need optimally would be all of the above items to work in sync with each other $6000+ for parts and labor.
    All I am saying is simply getting an intake and exhaust will do almost nothing power wise and will cost a lot of money to have a loud high RPM.
  14. Mar 23, 2012 at 5:09 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    I was actually directing it to the OP but yeah I see your point of money well spent.
  15. Mar 23, 2012 at 5:12 PM
    Manwithoutaplan
    ID
    my question is how late is to late to put a blower on???
    if you have engine with 100k is that to late???
  16. Mar 24, 2012 at 9:20 AM
    2010TRD
    Thomas
    Waldo, FL
    Ok so I'm going to stay stock.
    Use the extra cash saved to go with bumpers and lift.
    Thanks for all the good replies.
  17. Mar 24, 2012 at 9:22 AM
    2010TRD
    Thomas
    Waldo, FL
    Won't a supercharger just suck gas?
    And for the quoted $4,000 for supercharger..... Doesn't include exhaust to get that extra air out of the motor.......
    Wouldn't you have to spend more $$ to get any advantage from a supercharger.......
    Just seems like a charger wouldn't do much good without headers and exhaust......
    Correct me if I'm wrong.....
  18. Mar 24, 2012 at 9:28 AM
    2010TRD
    Thomas
    Waldo, FL
    Without headers/exhaust you can expect 100hp gain from a charger 'alone' ?.?.
  19. Mar 24, 2012 at 9:34 AM
    2010TRD
    Thomas
    Waldo, FL
    Wow!!!
    Think I'm just gonna do a magna flow can
    I hear that adds a little hp and mpg without much change to sound levels
  20. Mar 24, 2012 at 9:48 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    On average, without any other supporting mods, like Whippersnapper02 mentioned, it will take your wheel HP from around 200, to ~300. Usually just a tad under. Intake and headers will bump you over.
