Intake/Exhaust? Noise Driving Me Crazy
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JonWB, Sep 18, 2024.
  1. Sep 18, 2024 at 11:42 AM
    JonWB
    JonWB [OP] Well-Known Member
    Jon
    Idaho
    2018 TRD OR Access Cab
    Two audio file formats listed below.
    I've had the truck to two reputable shops and although both heard the noise, they don't know where it's coming from or where to start to fix it. The last shop thought maybe it was coming from either the intake or exhaust. It's been a couple years now and it seems like it's very gradually becoming more and more common.
    To me, it sounds like a cross between a bird and a bottle rocket. I hear it while maintaining speed anywhere from 25-45 mph. It's difficult but not impossible to hear with the windows up. I cannot specifically duplicate it, but it happens on most drives, sometimes continually. Once the whistling noise begins, if I let off on the accelerator the noise gets cut short. Thats the only control I’ve found so far.
    If you have any idea where to start looking I'd appreciate it.
    2018 OR AC, 95K miles
    iPhone M4a format
    https://www.dropbox.com/scl/fi/q45modaj3m5om03j4nhsv/Best.m4a?rlkey=7euo3xomqdece9qqjmngtza43&dl=0
    Wav format (worse fidelity)
    https://www.dropbox.com/scl/fi/g14b3yczi4qr19fnjgxzb/Best.wav?rlkey=s6btrh19hg5izg0ypzxg9icet&dl=0
  2. Sep 18, 2024 at 2:03 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    spray wd 40 on the belt and see if it stops
  3. Sep 18, 2024 at 3:14 PM
    dcmsideshow
    dcmsideshow Well-Known Member
    Dan
    Arvada, CO
    2019 Toyota Tacoma TRD Off-Road
    Eibach suspension; Deaver Springs; Black Rhino wheels; Toyo tires; RSI SmartCap
    Is it a stickshift?
  4. Sep 18, 2024 at 4:13 PM
    JonWB
    Jon
    Idaho
    Automatic
  5. Sep 18, 2024 at 4:22 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    You can’t hear it with the windows up?
  6. Sep 18, 2024 at 4:30 PM
    JonWB
    Jon
    Idaho
    I don’t often notice it with the windows up, but it is still possible to hear it, yes, if you’re listening for it.
  7. Sep 18, 2024 at 6:29 PM
    WinterFalco
    WinterFalco Well-Known Member
    Donald
    2018 Midnight Black SR 4x4 Double Cab
    Added aftermarket Rims and Tires, Fog Lights, Mudflaps, Entune with Nav
    My 2018 automatic does the same thing and has from days one. I am at 80K miles and have done all the maintenance, diffs, trans and such. I have not had any issues. I think you are okay.
  8. Sep 26, 2024 at 1:39 PM
    beef ranger
    beef ranger Well-Known Member
    19 OR 4WD 6MT DCSB CEMENT
    Is it worse when it’s cold out?
  9. Sep 27, 2024 at 3:07 AM
    JonWB
    Jon
    Idaho
    Not that I’ve noticed. The windows are up more in the winter, which makes it harder to track, but I haven’t heard an obvious change.
  10. Jun 19, 2025 at 11:38 AM
    JonWB
    Jon
    Idaho
    BUMP in case anyone can help me out before I tear my hair out and the truck apart.
  11. Jun 19, 2025 at 11:43 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Sort of sounds AC related. Try hitting the ac off button as soon as you hear the noise.
  12. Jun 19, 2025 at 11:46 AM
    JonWB
    Jon
    Idaho
    Thanks for the reply. I don’t use the AC very often so it definitely happens with AC off. I can try to see if there are any differences with it on.
  13. Jun 19, 2025 at 11:49 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Could it be the holes in the lower control arms? Try covering them with something like duct tape?
  14. Jun 19, 2025 at 12:01 PM
    JonWB
    Jon
    Idaho
    I’ve seen those posts and listened to the clips, but it doesn’t seem to be the same thing. I’ll still try covering them just in case.
    tonered[QUOTED] likes this.
  15. Jun 19, 2025 at 12:51 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good luck!
    :cheers:
