Intake/Filter Showdown
Discussion in 'Performance and Tuning' started by Ben_Schwarz_09, Sep 25, 2008.
  1. Stock Drop-In Filter, a in Stock Air-Box
    52 vote(s)
    15.1%
  2. K&N Drop-In Filter
    80 vote(s)
    23.2%
  3. AFE Pro-Dry S Drop-In Air Filter
    70 vote(s)
    20.3%
  4. K&N 63 AirCharger CAI
    49 vote(s)
    14.2%
  5. AFE Stage 2 Pro-Dry S CAI (TRD)
    54 vote(s)
    15.7%
  6. Snorkel
    6 vote(s)
    1.7%
  7. URD True CAI
    34 vote(s)
    9.9%
  1. Nov 11, 2008 at 11:09 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    They do get damp from road spray. The trick is in keeping the water out of the engine. If I had to guess, I would say that the URD intake accomplishes this with the 2 bends and the upward slope of the intake.
  2. Nov 15, 2008 at 8:42 PM
    crasch
    crasch Member
    San Diego, CA
    08 Rugged Trail Ed. w/Super Charger
    Rugged Trail equipped, TRD Cat Back Exhaust, TRD Super Charger, Rock Sliders, NAV DVD Radio
    So far only thing I can get is the K&N Drop in filter, Everything else is CARB Pending or not CARB Approved.
  3. Nov 25, 2008 at 3:30 AM
    craigFLA
    craigFLA Well-Known Member
    Ft. Lauderdale, Florida
    Tacoma TRD Sport Pkg.#1, XSP Package
    Leather, 20" rims, Borla cat-back exhaust, running boards, back up camera/3" screen in rear view mirror, carbon fiber interior trim. Tow Package. MODS: URD intake BHLM. Tinted tails & 3rd brake light Fog Light mod. 5pc Grill Craft (High Gloss Black powder-coat) T-Rex eye-lids AVS Wind Deflectors 3M Window Tint 15 front/30 rear OBX Sports Pedals Viper 5901 / remote start Pioneer AVIC F90BT-NAV Hybrid L8's in doors, L4's and Dynaudio MD102 tweets in custom kicks, morel rear-fill, JL TW5-13" sub, JBL MS-8, 2@Tru B475, Tru 4.65, PPI a600.2, PPI 456 X-over, Raamat BX2 and ensolite. relocated rear seats 3/4" Retrax cover electric dual "dead-bolt-lock" electric tailgate lock. electric Dynalock for Retrax Cover/custom fabricated case. kinetik second battery/power-gate isolation. Powerslot Cryogenic rotors, Hawks HPS Pads, SS lines,painted calipers&drums FULL trans flush mod OE Denso plugs
    I bought my URD intake used, and installed it this past weekend. My X-SP came with the Borla intake system (no engine cover).
    Installation isnt bad. You can cut the metal with anything, dremel, air body saw, etc. I started with my body saw, but it was messing up so I finished with red and green tin snips. I filed it down pretty, and painted the cut edge and surrounding area factory red to avoid rust. I didnt have the install kit (pattern and "combing" material), but the black door trim material I found at AutoZone worked perfectly. Turned out very clean and pretty:)
    THere are 5 wires to extend. Again, I didnt have the kit, but not a big deal. Just take your time, and solder and heat shrink everything. I used di-electric grease inside the plug to avoid water issues, as most problems associated with rain are at the plug (from my understanding). Also, push HARD, to be sure the plug is locked in!!! Mine wasnt the first time, but I double checked and tried again.
    I spend alot of time playing with the alignment, making sure piping didnt rub anywhere etc... I suggest removing the passenger headlight to cut the hole, then re-installing it BEFORE installing the intake, as after was impossible for me.
    Looks like adding power steering fluid might be difficult with this intake, as the piping runs just over the resevoir.... Not a big deal to me, but something worth mentioning IMO.
    Peformance--- I didnt expect such a difference above the Borla intake, but there is. Not too much noticeable up until 3500-4000 RPM, then there is a nice increase in accelleration. Very nice on the highway (my drive to work).
    SOund--- Again, no real difference at idle or normal cruising speeds in town, untill you stomp on it, or go to pass on the highway. Then, its sounds great!!! Much better then the Borla intake hands down.
    I live in SOuth Florida, and because of the HEAVY rains here I installed the K&N dry sock. I wouldnt recommend running this intake (in this climate) without it...
    Hope this helps...Good luck.
  4. Nov 25, 2008 at 7:09 AM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    I have run without the K&N Dry Charger in the driving rain at 75 MPH. I didn't have any issues with water in the pipes. The filter did get damp, but nothing got past that. Thanks for posting about the wiring. I had forgotten how many wires there were.
    Your X-SP, did it come with the Borla Exhaust as well? I am thinking about upgrading my exhaust, and I am looking at which way would be best for performance without adding too much of a note to it. I enjoy having a quiet cab on the highway.
    I completely agree with you on the passing at highway speeds. I had to pass an Acura TL that cut me off this morning. My other option would have been getting sandwiched between the TL and a semi truck. As I laid on it, the guy in the TL whipped his head around to see me fly past him. Then the semi laid on his horns as he almost rear-ended the TL.
    Damn, I love this intake. :burnrubber:
  5. Nov 25, 2008 at 10:12 AM
    craigFLA
    lol... now thats the ultimate advertisment..
    Thanks for the rep!
    Yes, it came with the Borla exhaust. It has a nice sound outside the cab, but its a little loud inside IMO. Others with similar set-up have disagreed though. I (like you) prefer a QUIET cab, so maybe I'm just too picky.
    I will be installing sound deadener with my system (within the next month hopefully), and hope that helps with the cab drone.
    If no, I may look into the Flowmaster Delta 50 muffler as an option. I've heard the sound outside is nice, but its designed to eliminate cab noise...
    The stainless tip off my Borla is already pitting/oxidizing anyway, so if/when I do the muffler change, I will probably replace the muffler back with SS tubing and a REAL stainless tip.
  6. Nov 25, 2008 at 11:06 AM
    norcalbb11
    norcalbb11 Nor*Cal
    Cali
    09 Taco Sport 4x4
    flowmaster 40 series, tinted windows, airaid CAI, removed 2nd filter, aries black bull bar
    i went with the airaid cai and i have noticed some power increase or its just my mind playing tricks on me, but i have that and the throttle body spacer and i love the whistle it makes and with my flowmaster 40 i love the whole setup and im getting 22mpg on freeway and 18-19 city so i am happy, i am trying to find a dry filter to put on the intake though.
  7. Nov 25, 2008 at 2:40 PM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    Yeah, I am looking at either the Borla, the Flowmaster, or the DynoMax Super Turbo muffler...
    For now, I am working on a security system and a sound system. I am in the process of purchasing some sound deadening from RAAMAaudio. I already did the rear panel in FatMat, but I wasn't impressed with the product. The results were pretty good though. I still have too much resonance and road noise from the doors to notice to much of a difference.
    :D
  8. Nov 25, 2008 at 2:42 PM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    Both Amsoil and AFE make good dry filter cones. The URD intake comes with a dry Amsoil filter that I think is great.
  9. Nov 25, 2008 at 2:43 PM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    BTW - I bought my URD intake used as well. I think the guy I bought it from was upgrading to the URD supercharger which comes with a bit of a different intake.
  10. Nov 25, 2008 at 2:44 PM
    norcalbb11
    norcalbb11 Nor*Cal
    Cali
    09 Taco Sport 4x4
    nice thanks for the info
  11. Nov 29, 2008 at 10:12 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Same for me.
  12. Dec 17, 2008 at 12:36 AM
    P. Bauer
    P. Bauer Well-Known Member
    San Jose
    08 Tacoma 4x4 TRD Off-Road
    TRD S/C :: Intake Camburg SwayAway Magnaflow American Racing Donahoe Racing Wheelers OffRoad
    have a brand new in box TRD filter for 05-09 Tacoma intake if anybody is interested.
    email me.
  13. Dec 19, 2008 at 9:12 AM
    ham-biscuits5000
    ham-biscuits5000 Member
    raleigh nc
    99 Tacoma TRD v6 4x4
    Is a akimoto intake kit a good one?
  14. Dec 19, 2008 at 3:22 PM
    VooDooTrip
    VooDooTrip Defector
    Gilbert, AZ
    01' BSP S/C S-Runner
    S/C, URD fuel Upgrade, 2.2 Pulley, URD crank pulley, Truetrax locker, custom exhaust, plx, scangauge, D/P mod, amsoil drop in, 18x9.5 stern hyperblacks, ACA projectors, Grillcraft blackmesh, Performance Products valance, R/C Tails, B&M Short shifter, QA1 Coilovers all the way around, upgraded strut rod bars with heim joints, poly bushings everywhere lol, 1st model Streetacos bolt on four link!
    Honestly, unless you're FI it doesn't really make a difference except for noise.. Granted your truck will breath better, but unless you take all the restrictors off and do a full exhaust (header/highflow/piping) you'll see minimal to no gains.. you're butt dyno will say different (it's all in your head though) btw amsoil drop in ftw.. lol
  15. Dec 22, 2008 at 2:28 AM
    #35
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    285/70/17 Goodyear BFG KM2's, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    AFE Stage 2 FTW!
  16. Jan 7, 2009 at 10:58 AM
    #36
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    yeppers...at wide open throttle your moving.
    4.0 is a dog stock trying to pass, put on a CAI and it wakes it up over 4k all day.
  17. Jan 7, 2009 at 9:56 PM
    #37
    CAdiveTaco
    CAdiveTaco Well-Known Member
    Nor Cal
    2009 Taco DC LB Pre Runner TRD Sport
    Bed Extender, Bed matt, G4 Fold-a-cover, debadged, locked spare, taigate hoe clamp mod, TW stick
    With any of these units whether removing the 2nd stage, drop in or a full kit that requires cutting, will this cause any warranty issues?
    Thanks
  18. Jan 9, 2009 at 7:18 AM
    #38
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    No warranty issues. Most of the CAI go right from the throttle body, the entire secondary filter is gone
  19. Feb 8, 2009 at 11:21 PM
    #39
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Here...TRD CAI...
  20. Feb 11, 2009 at 8:39 AM
    #40
    [eric]
    [eric] Well-Known Member
    Eric
    Bend, OR
    2005 Tacoma TRD OFF Road
    I am a big fan of CAI. i love the way the sound and perform. i currently dont have one in my tacoma, but do plan on it. since i am not that close making this specific purchase i have not researched what different types are available for tacoma's.
    I was thinking that even a CAI with bypass valve might not be ideal for off road conditions with mud, snow, and water. I guess it really depends on the location of the opening of CAI. But i was thinking that or a short ram.
    anyone with suggestions or experience with these.
