Intake Manifold 3RZ-FE
Discussion in '1st Gen. Tacomas (1995-2004)' started by afretes08, Oct 19, 2019.
  1. Oct 19, 2019 at 11:19 AM
    afretes08
    afretes08 [OP] Member
    Tacoma Extra Cab DLX 2.7L
    Im replacing my cylinder head on my 3RZFE, the thing is i only found a 4 port cylinder and my truck is 8 port.. its possible to use (The 4 port cylinder head with the 8 ports intake) or i need to swap the intake manifold to 4 ports?
    If i swap to 4 port intake manifold i need to replace other parts or sensors?
  2. Oct 19, 2019 at 5:59 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    It might help to know what year your truck is and the donor. Things changed. 95.5-97 had distributors with camshaft sensor built in. Later the cam sensor was mounted on the side between #2 & #3 cylinders.
    Someone else will know better than I, but I think the intake has to match the head. 4 vs 8 port.
    Old_Truck likes this.
  3. Oct 20, 2019 at 5:46 AM
    afretes08
    My truck is 98.. dont know the donor year but i think is 2000+ because in that year 4 port became standard
  4. Oct 20, 2019 at 10:13 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    It's not compatible.
