intake manifold need help
Discussion in 'General Automotive' started by Maxola89, Sep 28, 2009.
  1. Sep 28, 2009 at 6:55 PM
    Maxola89
    Maxola89 [OP] Active Member
    Norton, VT
    2000 Tacoma 4WD Short Bed
    2.7 swap for a 2.4
    i have a 2000 2.7 i swaped it out for a 2000 2.4 but manifolds are a little bit different should i take the one off the 2.7 and put it on the 2.4???
  2. Sep 28, 2009 at 7:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Im not sure I understand your question...
  3. Sep 28, 2009 at 7:37 PM
    Maxola89
    Norton, VT
    2.7 swap for a 2.4
    my truck was originally a 2.7 i swap the engine for a 2.4 the manifold on the 2.4 doesnt quite connect to everything so should i take the manifold off the 2.7 and put it on the 2.4??
  4. Sep 28, 2009 at 7:55 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Chris, here is the question with puncutation:
    His truck came originally with a 2.7L motor. He has since swapped it out for a 2.4L, however the intake manifold does not fit correctly. Can he put the old 2.7L manifold on the new 2.4L engine?
  5. Sep 28, 2009 at 8:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL!! Thanks, Dgerm!
    Give it a try. :eek:
