Intake Manifold Removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tom Ferreira, Aug 26, 2017.
  1. Aug 26, 2017 at 9:18 AM
    Tom Ferreira
    Tom Ferreira [OP] Member
    Tom
    2005 access cab, 4 cyl, auto trans
    none
    Hi All,
    I have a 2005 Tacoma, 4 cyl with an automatic transmission.
    My problem is I'm change the cooling system bypass pipe. In order to do so the intake manifold needs to be removed. I've removed the two nuts and three bolts and disconnected all the hoses and plugs. The manifold will not move. I tried tapping it with a block of wood and a hammer, no luck. I'm afraid of cracking the manifold if I hit it too hard. Any Ideas????
    TXpro4X4 likes this.
  2. Aug 26, 2017 at 9:31 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    There's still a bolt somewhere find it and remove it
    TXpro4X4 and Bebop like this.
  3. Aug 26, 2017 at 9:58 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    This!!! There is always a hidden bolt. Always
  4. Aug 26, 2017 at 2:58 PM
    Tom Ferreira
    Tom
    none
    Well you are correct. I found two bolts, removed them and DAM! it came off. Thank you for the help. I would like to find the engineer how came up with this PLASTIC BYPASS PIPE idea and beat him/her over the head with it.
    Tom
  5. Aug 26, 2017 at 4:28 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    :rofl: I'm sure a lot of us would like to do the same thing to engineers :thumbsup:
    Bebop likes this.
  6. Aug 26, 2017 at 6:14 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    If they save $1 on a plastic pipe and 1,000,000 trucks that's $1,000,000 and we are stuck with the results.
  7. Aug 26, 2017 at 6:28 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    How many miles on the taco?
  8. Aug 26, 2017 at 7:31 PM
    Bebop
    Nick
    I seriously think engineers have office pools going to see who can get the most ridiculous idea into production.
  9. Aug 26, 2017 at 7:39 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Make sure that you get the correct updated Metal Replacement Pipe. 16268-75110 is the bypass pipe in steel, The gasket is 16258-75021.
  10. Aug 26, 2017 at 7:54 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    I bet they're like where can I put this so you have to remove the entire motor just to get to it :devil:
  11. Aug 27, 2017 at 6:51 AM
    Bebop
    Nick
    Like the oil pan gasket on a g35
