intake resonator delete?
Discussion in '4 Cylinder' started by vtragweed, Aug 10, 2009.
  1. Aug 18, 2009 at 4:09 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    the ram air effect they get, combined with it going in as a 2nd air inlet, makes it convincing, k&n type intakes only use the 1 from the fender if im not mistaken. Interesting idea of doing a deckplate mod with an added ram air, if i could pull it off easy, could get me around our 2 year inpection.
  2. Aug 18, 2009 at 4:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    A "Ram Air" intake is not going to have much affect on an engine below 80 mph or so. Also...Keep in mind that the factory intake is a "Tuned" intake.
  3. Aug 18, 2009 at 4:17 PM
    Tacoyota
    08 4wd
    If the empirepao data is close to accurate, im just thinking the 2nd tube must have helped a lot, and im interested to see them put a magnahelic guage in there to show if there is pressure building with acceleration. Im interested , but not enough to use my truck as a guinea pig.
  4. Aug 18, 2009 at 5:39 PM
    otter
    otter Well-Known Member
    Rob
    MI
    09 4 cyl Reg Cab
    You really think K&N, or any other major intake manufacturer, puts that kind of effort into their intakes? I assure you they don't. They look at the application, pick the pipe diameter (based on the stock intake diameter at the maf) then design a pipe to place the filter where it's convenient. That's about it.
  5. Aug 18, 2009 at 6:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Bingo.
    specter208 likes this.
  6. Aug 18, 2009 at 6:33 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Honestly what do you expect from a company that has made such a name for itself for providing a filter that does not actually filter? I am referring to the strenuous third party testing that has found silica levels in oil samples off the charts when using K&N filters and cold air intakes;)
  7. Aug 18, 2009 at 6:33 PM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    :proposetoast:
  8. Aug 19, 2009 at 4:40 AM
    sriley727
    sriley727 Well-Known Member
    Aiken, SC
    08 Reg cab PreRunner SR5
    Bone stock
    http://www.knfilters.com/testmethod.htm
    http://www.knfilters.com/powertesting.htm
    Nah, they don't do none of that "testing" stuff!
    http://www.bobistheoilguy.com/airfilter/airtest3.htm
    They don't filter much worse than everything else on the market.
    I agree, most CAI manufacturers just cobble parts together and don't take into consideration things like how they've changed the airflow in front of the MAF or how much hotter the air is they are letting in than the stock setup. K&N and a few other reputable companies are different.
  9. Aug 20, 2009 at 5:47 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    from what i read and "understood", im very slow and take things the wrong way many times, but isnt the engine on a close looped circuit meaning that the maf calibrator wont do anything until after the loop goes to open around 3k or something? and then who drives their trucks above that regularly to have a significant difference in their dd.
    i was talking with someone who had it installed it in their 4 banger over on ty i think and he said ya his butt dyno really felt it when he was wot and at high rpm's and nothing too significant on the low end.
    again im wrong alot of the time lol
  10. Aug 20, 2009 at 6:19 AM
    sriley727
    Aiken, SC
    Bone stock
    Your engine is in closed loop when it is below operating temperature. Once the temp gets up, it goes into open loop and uses the O2 sensors to regulate the air/fuel mixture. It does this at all rpms.
  11. Aug 20, 2009 at 6:20 AM
    08pretaco
    az
    interesting thank you
    so then what exactly does the maf calibrator do if 02 sensors do everything? does it lean it out cause the factory tune runs rich or something
    nvm lets you do what you want just looked it over at urd
  12. Aug 20, 2009 at 7:17 AM
    otter
    Rob
    MI
    09 4 cyl Reg Cab
    O2 sensors don't do everything. At over 80% throttle (basically WOT) the MAF takes over fuel control.
  13. Aug 20, 2009 at 7:31 AM
    08pretaco
    az
    so then im guessing this in when the maf calib comes into play or does it still have an impact when the 02 sensors are doing their thing?
  14. Aug 20, 2009 at 7:41 AM
    otter
    Rob
    MI
    09 4 cyl Reg Cab
    Correct. MAF calibrators only effect fuel when the ECU is in open loop, which it only hits at WOT. If you want to control the fuel in all circumstances, you need to either be able to flash the ECU (doubt anybody has figured this out on Tacos) or go full standalone, such as an AEM EMS.
  15. Aug 20, 2009 at 7:43 AM
    #35
    08pretaco
    az
    so does temp have anything to do with open/closed loop like mentioned above?
  16. Aug 20, 2009 at 7:48 AM
    #36
    otter
    Rob
    MI
    09 4 cyl Reg Cab
    You've got it backwards.
    Cold engine and/or WOT = ECU in open loop, reading from fuel maps.
    Hot engine w/less than 80% throttle = ECU in closed loop, using O2 sensors to hit 14.7 afr.
  17. Aug 20, 2009 at 7:58 AM
    #37
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Alright, I gotta know what this part is. I am pretty dumb today lol. Any pics to help me visualize?
  18. Aug 20, 2009 at 8:10 AM
    #38
    08pretaco
    az
    alright this is starting to make more sense and why people decide to go with the maf cal.
    for me it makes no sense because im very rarely over 80% open throttle so the truck does what it wants to do but glad i finally understand why the rave about it is thanks otter!
  19. Aug 20, 2009 at 10:07 AM
    #39
    sriley727
    Aiken, SC
    Bone stock
    yes, I do have it bass ackwards.
    http://www.sjmautotechnik.com/trouble_shooting/10vo2sen.html
  20. Aug 20, 2009 at 11:04 AM
    #40
    otter
    Rob
    MI
    09 4 cyl Reg Cab
