Intake resonator removed, good or bad?
Discussion in '4 Cylinder' started by vtragweed, Sep 19, 2011.
  1. Sep 19, 2011 at 2:44 PM
    vtragweed
    vtragweed [OP] Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    I'm fooling around with the truck today looking for stuff to do. I'm thinking of taking off the resonator anything wrong with that good, bad or does it matter or will it effect the performance at all?
  2. Sep 21, 2011 at 3:44 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I took mine off a couple years ago. I think it gives a little more response to the throttle and makes the intake a little louder. Kind of like the elbow mod or deckplate mod on the 1st gens. I doubt the performance gains are huge if any.
    I've heard some people say that the resonator helps keep water out of the intake, but with it installed the air intake is actually lower in the fender.
    It's pretty easily reversed if you take it off and don't like it.
  3. Sep 21, 2011 at 3:55 PM
    2007 tacoma
    2007 tacoma Well-Known Member
    LEEEEEEROOOYYY JENKINS!
    2007 Access Cab
    16" Alloys, K&N intake, Class III Hitch, US Truck Cap Rack, Carpeted Bed Mat, WeatherTechs, SeatSaver covers, Many more in the works
    I've heard nothing but good things about taking it out. I'm of the impression it's there to make the engine quieter at the expense of airflow.
  4. Sep 21, 2011 at 4:10 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    well i asked this same question a few years back, and seeing a few people took them off awhile back i wanted to see how they like it and pros & cons about it.
  5. Sep 21, 2011 at 6:20 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I'll probably take mine off when I'm bored one day...haha
  6. Sep 21, 2011 at 6:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I did some test a while back on a couple different vehicles, with the resonators removed, and in place. It made no difference in hp, or tq.. The only thing they affect is the sound. Nothing more.
  7. Sep 21, 2011 at 6:23 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I hope you realize Chris, all the advice I give people on here is from you...:p
  8. Sep 21, 2011 at 6:25 PM
    rcfreak201
    rcfreak201 Well-Known Member
    how do you do this mod? is it only on stock intakes or CAI's too?
  9. Sep 21, 2011 at 6:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    DOnt you EVEN try to tell people I told you to change your oil the way you did....
  10. Sep 21, 2011 at 6:29 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    oh, so youre the one.
  11. Sep 21, 2011 at 6:31 PM
    rcfreak201
    nevermind, thanks:cool:
  12. Sep 21, 2011 at 6:33 PM
    Sanders17
    Sanders17 Well-Known Member
    Reed
    Livingston, TN
    Black Sand Pearl 08 TRD Offroad
    Increase sound thats about it. Youre imagination may think more HP but no.
  13. Sep 22, 2011 at 5:51 AM
    JEA86
    JEA86 Well-Known Member
    Jeremy
    WV
    2016 TRD Off-Road
    i took mine out noticed a bit quicker throttle response but i done this at the same time of doing the AFE high flow air filter so who knows, but it is a bit louder at cruising speed
  14. Oct 27, 2011 at 2:13 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    took mine out. Intake is at a higher level in the fender well than with it in.
  15. Jan 5, 2012 at 7:09 PM
    TacoKing1992
    TacoKing1992 New Member
    Houston
    2001 PreRunner TRD
    Michelin A/t, MB Chaos Rims, P&P Throttle Body, Magnaflow Single Exit Exhaust, Volant Cold Air Intake, 4.88 Gears, Jett Throttle Body Spacer, Jett Programmer.
    How do you remove your intake resonator? I have an intake that requires me to cut a hole in the intake tube, and I don't feel comfortable doing that. So I would like to remove my intake resonator. Any help would be greatly appreciated.
