Intake Valve Cleaner
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Backstrap, Jul 4, 2018.
  1. Jul 4, 2018 at 6:57 AM
    Backstrap
    Backstrap [OP] New Member
    2016 White TRD Sport
  2. Jul 4, 2018 at 7:09 AM
    Clearwater Bill
    Billy
    Largo Florida
    Curious why intake valves on a '16 would need attention?
    That said, i like crc products. But for top end cleaning ive found Techron or Seafoam to work just fine.
    kgilly and BillsSR5 like this.
  3. Jul 4, 2018 at 7:25 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    The 3.5 V6 Tacoma has both direct and port fuel injection, so if you want to clean the system, pour some Techron in your fuel tank.
    I've seen Techron clean some really nasty deposits off of the valves in one of my motorcycles.
    tonered likes this.
  4. Jul 4, 2018 at 7:36 AM
    jboyorak
    jboyorak Well-Known Member
    As was said right above me, the 3.5 has both PI and DI, so in theory the valves should get somewhat cleaned through the port injection process. Also, many DI only motors will use valve timing to keep the intake valves clean. I do not know if the 3.5 Tacoma utilizes this process.
    I do want to add that I have not seen the condition of the valves or the intake after some mileage, so it is difficult to give a definitive answer.
  5. Jul 4, 2018 at 8:43 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Warm your truck up, then drive it in the higher rpm range, 4500-6000, for a few minutes, like ascending a long hill.
  6. Jul 4, 2018 at 9:30 AM
    Clearwater Bill
    Billy
    Largo Florida
    Modern version of the Italian tuneup? :D
    tonered likes this.
  7. Jul 4, 2018 at 9:44 AM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    On a 3rd Gen engine maybe after 200k miles might consider using these CRC.. :cool:
    BillsSR5 likes this.
  8. Jul 4, 2018 at 7:33 PM
    eurowner
    eurowner Duke Sky
    Scoty
    :cool:
  9. Jul 5, 2018 at 8:32 AM
    deuceb
    deuceb Well-Known Member
    Denver | Austin
    2018 Taco BBPDCLBTRDOR | 2004 MB SL55 | 86 VW GTI
    The only thing I like is to occasionally pour a bottle of Lucas Upper Cylinder Lubricant in the gas tank maybe 2-3 times a year. I've seen gas mileage improvements in my older vehicles. Otherwise maybe Seafoam when you hit 100k miles?
  10. Jul 5, 2018 at 9:30 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    FYI, the motor will do a self cleaning if right conditions are met, you will notice sometimes after the motor is warmed up if its idiling it will get wacky and noisy, this is the self cleaning process taking place.
  11. Jul 5, 2018 at 9:33 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
  12. Jul 5, 2018 at 9:52 AM
    salmonmigration
    salmonmigration Well-Known Member
    2018 TRD Sport 6MT
    Are you running your truck on 2-cycle premix? Why do you think you have fouled intake valves?
  13. Jul 5, 2018 at 9:55 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I believe the cleaning cycle on our truck occurs during sitting at idle, go order some food at a busy drive-thru and you will be good to go.
    Kabogski and Lawfarin like this.
