Integrated reverse lights into stock bumper & painting black (how to)
Discussion in 'Lighting' started by APTJ, Dec 25, 2010.
  1. Dec 25, 2010 at 5:02 AM
    APTJ
    APTJ [OP] Well-Known Member
    Eric
    Texas
    2005 Dcab SR5 4x4
    grill, lights, bull bar, rims, tires,
    Code:
    alright..so backing up my driveway at night was getting kinda sketchy w/ tinted tails and tinted windows...
    So I'm getting new lights for where I had these mounted in the bed so I moved them to the bumper.
    To start this project you will need to remove the bumper..
    then tape lines from bolt to top of bumper for a straight and even line on both sides of the bumper for symmetrical cuts for the lights..(sry no pics for now on these steps.)
    measure holes, and cut
    I used a die grinder to get a hole started and then cut with reciprocal saw the rest of the way. heres how it looks with the holes before painting
    remove all plastic from bumper.(for the most part plastic tabs)
    then when sanded the bumper until completely dull and applied 4 coats of grey primer.
    half painted half primer (gloss black krylon)
    all painted (4 coats again)
    then applied 2 coats of gloss.
    then mount..and prepare for wiring
    To power these lights a relay will be needed as it is no where near enough power if connected to reverse lamps in stock tail lights (TL). Sooo..this means run a wire from your battery to a relay that can be installed inside the TL area..then w/ the truck off put it in reverse (flat ground and block it)..use a tester to find which connection is the reverse power and tap into that (pink w/ white stripe).
    Then connect that to the S (switch) on the relay..connect the L (lights/load) to a wire that will run to the reverse lights. and finally the wire that is running from the battery to B...the relay I used grounds to the case as you can see here...
    Then intstall and wire lights..to hold the lights in place I bent the housing so it would be tight when pushed in and added emblem glue around for an extra stick..then added silicone around the outside for a seal.
    Finished product:
  2. Dec 25, 2010 at 5:04 AM
    APTJ
    Eric
    Texas
    2005 Dcab SR5 4x4
    oh yea..Merry christmas TW..haha got my presents now I just have to wait for daylight to go play with my new tools! haha
  3. Dec 25, 2010 at 5:11 AM
    daftcon
    daftcon too many clowns, not enough circuses.
    François Dillinger
    places
    '05 PreRunner
    just about black everything. i don't dig the chrome.
    dude thats pretty badass. im gonna be repainting my bumper eventually, and this is something i will for sure consider. good work!
  4. Dec 25, 2010 at 6:27 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Gutsy mod but it looks pretty good!! Good job!! Hey how did you take that 2nd to last pic with the truck in reverse but no one stepping on the brakes!!:eek::laugh:
  5. Dec 25, 2010 at 6:42 AM
    1badhd
    1badhd Master Technician
    1badhd
    Pennsylvania
    2011 TRD Sport DCLB Debadged and Blacked Out
    Key on engine OFF......gear selector in reverse!!!:devil:
  6. Dec 25, 2010 at 7:51 AM
    APTJ
    Eric
    Texas
    2005 Dcab SR5 4x4
    and w/ park brake ON..haha
  7. Dec 25, 2010 at 7:51 AM
    articcs22
    articcs22 Well-Known Member
    chris
    Abington, MA
    2007 tacoma DCLB
    dynomax super turbo muffler, aem pro dry s drop in, ebay crappy black headlights with HIDEXTRA 6000K Low beam HIDS, Bilstein 5100's in front, Northern tool black toolbox, Extang tool box tonneau, Debadged, Tinted windows all around, Lund ventvisors all around, AVS smoked tailight covers, Hella black magic 1000's mounted on a westin off road light bar
    what kind of lights did you use? bright?
  8. Dec 25, 2010 at 8:09 AM
    APTJ
    Eric
    Texas
    2005 Dcab SR5 4x4
    $20 dollars at auto zone...no seal or discoloring problems while I had them mounted in the bed so i figured they'd be good and easy to replace if I hit the light on something..they're pretty bright but im sure there's brighter. Pics tonight of truck in reverse
  9. Dec 25, 2010 at 8:11 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Nice work. Almost makes me wanna cut up my bumper. But not quite....Gotta collect a few more tools first.
  10. Dec 25, 2010 at 8:33 AM
    APTJ
    Eric
    Texas
    2005 Dcab SR5 4x4
    Same..i'd really like to build my own but Im short of some training and tools also..guess i can just perfect the sketchup for now and dream on
  11. Dec 25, 2010 at 6:33 PM
    APTJ
    Eric
    Texas
    2005 Dcab SR5 4x4
    and the night pics i promised:
  12. Dec 25, 2010 at 6:36 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Legit Mod!:cool:
    +1
  13. Dec 25, 2010 at 6:43 PM
    TacoMal
    TacoMal Well-Known Member
    California
    09 TRD Off Road Dbl cab
    Wet Okole's, Relentless Sliders, Plasti Dipped badges and wheels
    They obviously don't work... You ran over the curb!! J/K :laugh:
    Nice work! Looks great! :cool:
  14. Dec 25, 2010 at 6:58 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    awesome job. Not bad for a young fellow!
  15. Dec 25, 2010 at 7:10 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    Nice work!
    If i wasn't planning on a plate rear I would be doing this soon. But def a good reference for the wiring :thumbsup:
  16. Dec 25, 2010 at 7:31 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
  17. Dec 25, 2010 at 10:15 PM
    APTJ
    Eric
    Texas
    2005 Dcab SR5 4x4
    Thanks guys
    haha..I want to build my plate bumper :cool:
  18. Dec 26, 2010 at 11:42 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Nice work!! I'm really liking that! Our stock reverse lights definitely blow.
    It looks like they're aimed a bit off though. Not that it really matters, but it'd probably bother me. Can you adjust up/down on them or no?
    :laughing:
  19. Dec 26, 2010 at 5:30 PM
    APTJ
    Eric
    Texas
    2005 Dcab SR5 4x4
    I suppose you could but with the angle of the bumper that is the way they sit when flush and I'd prefer them flush over angled. In the pictures the main concentration of the light does seem to be aimed pretty low but overall light is still very bright and fills out the area behind and to the sides well.
  20. Dec 26, 2010 at 6:31 PM
    APTJ
    Eric
    Texas
    2005 Dcab SR5 4x4
    thought i'd make a quick vid with the new gopro
    that main pt. of light is about 10 ft from the bumper...it could stand to be aimed a bit higher.
