Integrating FJ switch to Rigid light
Discussion in 'Lighting' started by Sgian, Mar 3, 2013.
  1. Mar 3, 2013 at 5:35 AM
    Sgian
    Sgian [OP] Dark humor is like food, not everyone gets it.
    Louisiana
    2011 Sport DCSB Manual V-6 SC
    TRD Super Charger, URD 2.8 Super Charger Pulley, URD headers and full system, URD fuel pump upgrade, URD Short throw Shifter, AFE CAI, OME 886 coilovers with Nitrochargers, Dakar Leaves, Desert Products UCA's, FJ TRD Anthracite rims, BFG AT/TKO 285s, Redline Hood struts, Weathertech Ventshades, Weathertech Floormats, Speed Dawg shift knob, Coupe solid shifter, Relentless all around, Eyelids T2, Mr Yo Rearview mirror lift, ejector seats, Rigid D2s front and back, Rigid Light bar in skewp.
    Has anyone done this? I am sitting here, looking at the six pin FJ accessory light switch and my three wire Rigid light bar wiring harness and scratching my head. Wires 5 and 6 I understand, will tap into the power and ground from my fog light switch. 1, 2, 3, 4 have me stymied. I know 1 is power to the "on" led. 2 is ground for the light. 3 is power in for the accessory light. 4 is power to the light. I am just having trouble thinking of how I need to splice this into the Rigid system. Any advice would be more than welcome. Thank you for your time.
    21085d1204908836t-oem-aux-light-switch-d_009fedd927a0507f14d70919d45e5a498e82d98d.jpg
    For the life of me, I cannot find a wiring schematic for the Rigid wiring harness.
  2. Mar 4, 2013 at 5:20 PM
    BytorTruck
    BytorTruck Well-Known Member
    Brandon
    Scottsdale AZ
    Did you get it figured out Matt?
  3. Mar 5, 2013 at 1:52 AM
    Sgian
    Louisiana
    Not fully. I am going to attempt to wire it up this weekend. There will undoubtably be some error and trial going on. My best guess is going to be blue wire to 1, black to 2, red to 3 and black to 4 again. Hopefully I don't blow up the system.
  4. Mar 5, 2013 at 11:09 AM
    BytorTruck
    Brandon
    Scottsdale AZ
    This is what I would do. Dont run any wires into the cab. Cut the Red Black and Blue off the switch on the Rigid harness. Cap off the Red and the Black wires off. Take the blue wire from the rigid harness and T-tap it with the positive fog light wire any where between the factory relay and factory fog light bulb.
  5. Mar 5, 2013 at 3:35 PM
    Sgian
    Louisiana
    I am planning to put in a separate switch from the factory fogs. I have bought an FJ switch, and wanted the "On" light for that switch to function.
  6. Mar 12, 2013 at 5:12 AM
    Sgian
    Louisiana
    Ok, figured it out. I had been searching all over the interweb for a wiring diagram for the Rigid light bar. Turns out the instructions that came with the D2s included what goes where for the bar :facepalm:.
    So then integrating it into the FJ switch was a little nerve wracking, ended up calling my dad to double check as I didn't want to burn out the switch itself. Ended up being 1 to blue, 2 to black, 3 to red, 4 to blue again, 5 got connected to wire 4 of the adjacent fog light switch, 6 to wire 3 of fog light.
    and then all closed up:
    and working:
  7. Mar 12, 2013 at 5:16 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Nice! I have got the cheapo factory light switch. I want this one.
  8. Mar 12, 2013 at 8:38 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Where did you get the switch from?
  9. Mar 13, 2013 at 12:50 AM
    Sgian
    Louisiana
  10. Mar 13, 2013 at 1:18 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    glad u got it working. wish i would hava eseen the wiring diagram to give u some insight when u were asking me
  11. Mar 13, 2013 at 9:59 AM
    Mitch
    Mitch
    Spokane, WA
    Thanks.
    So if I wanted to hook up a set of lights to that switch how would I get the other end of the plug to be able to plug into the harness?
  12. Mar 13, 2013 at 4:21 PM
    Sgian
    Louisiana
    The only one I know for certain is the rigid harness. I do not pretend to be an electrical engineer, the only circuits I wired prior to this was to blow something up. I can take a crack at your question if you have the wiring diagram for your set of lights, but no promises. I normally destroy things rather than create.
  13. Mar 13, 2013 at 4:41 PM
    Sgian
    Louisiana
    Dude, you just made me run outside and check. It does infact dim and brighten with the rheostat control at the same rate as the fog light switch. And now to hijack my own thread.... Do you bychance have a copy saved of your fog lights a'la Caribe hidden anywhere? I would really prefer your elegant solution to the one I am currently running/
  14. Mar 13, 2013 at 5:08 PM
    Mitch
    Mitch
    Spokane, WA
    Well most of the light I've been looking at are just +/- wires. I have no issue wiring them up to a standard switch. I like the fact that we can hijack a FJ switch and make it look stock.
