interchangeable wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Engine 5, Mar 1, 2011.
  1. Mar 1, 2011 at 2:52 PM
    Engine 5
    Engine 5 [OP] Member
    paige
    illinois
    08 tacoma 4 door
    Does anyone know if alloy OEM wheels from a '07 4runner will fit a '08 tacoma?
  2. Mar 1, 2011 at 2:55 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    6x5.5 wheel?
  3. Mar 1, 2011 at 2:55 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    if its a 6 lug i believe they are the same bolt pattern
  4. Mar 1, 2011 at 3:41 PM
    mach1man001
    mach1man001 eh whatever
    Rob
    Blackstone, MA
    '09 Sport DCLB Met Grey
    Toyota bed mat (1st mod), Toyota all season floor mats, Rear spring TSB, Map light mod, Fog light mod, Putco yellow fog bulbs, Weather Tech window vents, Extra d-rings, Mounted mag light, TRD CAI with AFE pro dry filter, '05 front mud flaps (winter only), 2 set's of wheels/tires, 285/75/16 Hankook MT's, Black Painted 1st Gen TRD wheels (wheeling set) Black powder coated FJ Cruiser with 265/70/17 BFGoodrich KO2's (everyday), painted center of grill & bumper black, Devil horns, OME with 885's + spacers front, OME shocks w/OMD designed rear springs, Front diff drop, Rear trailer plug relocate, ATO IFS skid, Relentless Trans & Transfer skids, BAMF bolt on rock sliders, Relentless tailgate reinforcement, Uniden 75 CB radio, BAMF antenna bracket, TRD exhaust, high lift jack w/ATO mounts. And of course ProEFX Towing Mirrors!
    The offset may be different though.
  5. Mar 1, 2011 at 4:11 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Same bolt pattern. Most likely will fit fine, because the front suspension is very similar.
  6. Mar 1, 2011 at 7:19 PM
    Engine 5
    paige
    illinois
    08 tacoma 4 door
    Yes, 6x5.5
  7. Mar 1, 2011 at 7:23 PM
    Engine 5
    paige
    illinois
    08 tacoma 4 door
    I was under the impression that the 4runner was built on a taco chassis so they should fit. The problem is that I don't know what the offset is on the OEM stamped steel wheel, or how much difference that will make.
  8. Mar 1, 2011 at 8:03 PM
    KenLyns
    Belly of the Beast
    OEM steel (both the silver spoked and black wheels) should be 0mm offset.
  9. Mar 4, 2011 at 3:59 PM
    Engine 5
    paige
    illinois
    08 tacoma 4 door
    Thanks. I had not been able to find that number. That helps. I think the 4runner rims have a 20mm offset. Is that a deal breaker
