Interest in AFE Group Buy????
Discussion in 'Group Buys' started by mceagle555, May 19, 2008.
  1. Jul 22, 2008 at 8:26 AM
    #381
    StompinStu
    StompinStu Active Member
    Baton Rouge, LA
    06 PreRunner Access Cab I4 5 speed
    I thought computers were programmed by humans. If I knew my truck had artificial intelligence I would have been expecting a lot more from it.
  2. Jul 22, 2008 at 10:33 AM
    #382
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Not AI, but the auto's adjust shift points and other key functions based on your driving style.
  3. Jul 22, 2008 at 10:37 AM
    #383
    piercedtiger
    Jon
    Southern Tier, NY
    You both have auto's right? Seems interesting that you saw an initial drop while my manual didn't. Do both of you have the secondary air filter removed? Either of you remove it just before switching to the AFE?
    Just curious if the engine is suddenly getting a lot more air, generating more HP, and you're not compensating by using less skinny pedal.
  4. Jul 22, 2008 at 10:41 AM
    #384
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    auto, secondary air filter removed b/4 I got the new AFE drop in.
    I'm not driving any different. My daily drive is the same, 20 mins at 65MPH cruise control then 20 mins at 75 MPH cruise control.
  5. Jul 22, 2008 at 11:02 AM
    #385
    StompinStu
    Baton Rouge, LA
    Yes, on demand though. Not learned, remembered, and retained for future use. It's a computer, not a brain. The computer was programmed what to do for the different air,fuel, load, and throttle combinations that it will be presented with.
    The computer does not 'know' what is best, it reacts with what it was programmed is best. Case in point, you can change the programming by swapping out chips for most vehicles. You can get performance chips, or economy chips. The computers didn't learn these features. It was told them.
  6. Jul 22, 2008 at 11:10 AM
    #386
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Same here. I'm not looking at the first tank as any indication of future results. Just figured I'd post my initial findings.
    You're talking about semantics. You know exactly what he meant by "learn". Will you go through another lengthy explanation when someone says they "ran" over to the local gas station when clearly they didn't actually run but drove?
  7. Jul 22, 2008 at 2:06 PM
    #387
    StompinStu
    Baton Rouge, LA
    Thanks for admiting your shortcomings.
    No, read his earlier statements. He really believes the computer has some sort of AI. It is just programmed to do what a human tells it to do, and reacts accordingly.
  8. Jul 22, 2008 at 5:33 PM
    #388
    piercedtiger
    Jon
    Southern Tier, NY
    So what you're saying is a human programmed all the 100's (1,000's? millions?) of data points the ECU uses to adjust shift points, amount of fuel to inject, valve timing, and all other things it adjust for every single rpm between zero and redline cut off? For every single individual mpg increase from zero to the fuel cut off around 114 or 120mph? For every possible amount of air between sea level and high elevation? For all octanes of gas from 85 to 93?
    I find it more plausible that a human simply programmed in calculations and formulas for the ECU to use to gain the most efficient combination based on current conditions. To me, that's a little more than a dumb machine simply following instructions. Your computer does exactly what it's told to do. It boots up exactly the same, doing the exact same things every time until something is changed. These trucks on the other hand can alter behavior based on conditions. It's not AI or "learning" like you learning to use the internet, but it IS "learning" in a sense that it adjusts settings based on certain conditions. Like if you drive like a grandma it will shift sooner. If you have your foot in it all the time flooring it to top speed it will shift later to give you more power. And it remembers these settings until the battery is unhooked or power is cut to the ECU. It doesn't just adjust for 10 minutes because you're going up a hill at the moment, and goes back to "normal" down the other side or when you turn the engine off.
    I don't recall him ever using the word "AI" in his post. :rolleyes:
    Oh, and for the record maybe you should read this:
    http://auto.howstuffworks.com/automatic-transmission8.htm
    hmmmm.... who's a tool now? :rolleyes:
  9. Jul 22, 2008 at 9:10 PM
    #389
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Yeah, no problem. You're still an egotistical fool, regardless. Your pathetic response only proves that further.
  10. Jul 23, 2008 at 2:24 AM
    #390
    glk21c
    MD
    I have to say, I'm sorry that I even reported my findings so far. Would have never guessed it would have turned into this.
  11. Jul 23, 2008 at 4:03 AM
    #391
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Don't be sorry.... you've done NOTHING wrong.
    Just ignore the riff raff - and report back to us again later.
    I just filled up yesterday, so for me...it'll be a while yet. I also put some techron in, so that might defer the results also.
    Honestly - Each situation is different and if people have complaints or gripes about the data your posting.....that's their problem. Not yours....
    Peace
  12. Jul 23, 2008 at 4:28 AM
    #392
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    I concur with Janster. I'm glad you posted that information. :thumbsup:
  13. Jul 23, 2008 at 5:03 AM
    #393
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    13 TRD OR DC MGM
    Stock for now
    Boy, I just got around to putting the darn thing in. :p
    Next up are my hood struts I bought last year!
    Thanks for posting numbers. I like the fact its re-useable. :thumbsup:
    The aftermarket one (Fram?) I replaced the AFE with looked horrible after only 2 months.
  14. Jul 23, 2008 at 6:14 AM
    #394
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i know i got in way late on the gb for the filter....but then again i traded my 06 for an 04........so, where is the cheapest place now that ya'll have seen to get the afe pro dry s filter?? im gonna get one for my 3.4 v6, and i also gotta get one for the wife's 02 honda accord!!
  15. Jul 23, 2008 at 8:40 AM
    #395
    StompinStu
    Baton Rouge, LA
    Was it good for you?
  16. Jul 23, 2008 at 11:23 AM
    #396
    Roland
    Rhode Island
    OK kids, play nice.
  17. Jul 23, 2008 at 12:06 PM
    #397
    06WHITETRD
    06WHITETRD Gotta Love my Taco!!!!
    So Cal
    06 Toyota Tacoma OFF-ROAD
    Tinted windows, window visors, XDI True Flow intake, White Devil Emblem, sport white grill, stubbie 6' antenna, TRD license plate frame,TRD Exhaust, weathertech floor front & rear, LED map/dome & license plate lights,Black Grille,T-Rex eyebrows,black Skid Plate,Lower bumper cover,Black emblems,white TRD Emblem,lamin-x yellow,Slotted & Cross Drilled rotors,Redline shocks(hood),HID 6k,more to come
    I am interested on the intake. how much would it be??? does it come with the CAI??
  18. Jul 23, 2008 at 12:09 PM
    #398
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hey man.....a cai is a "cold air intake"....which has the open filter box and filter. on the 4.0 motors........all you really need is to remove the secondary air filter and install an afe pro dry s filter in place of the stock filter. better mileage and possibly a bit more power. a cai only gives you power in the higher rpm's, which is kinda pointless if you are trying to save at the pump.
  19. Jul 23, 2008 at 12:11 PM
    #399
    piercedtiger
    Jon
    Southern Tier, NY
    Not to mention all the CAI's I've seen are $250-$400 when the AFE Pro Dry drop in filter is $50-$70.
  20. Jul 23, 2008 at 12:14 PM
    #400
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah....forgot to mention that too!!!:)
