Interested in a 4runner
Discussion in '4Runners' started by WhiteTaco19, May 3, 2019.
  1. May 3, 2019 at 11:44 AM
    WhiteTaco19
    WhiteTaco19 [OP] Well-Known Member
    Sin City
    2019 T4R TRD OR
    Have a 19 Taco plagued with vibration issues and the rumble strip vibration when slowing.
    Do you guys know if these are affected at all?
    Thinking of trading in my taco for a 4runner.
    Thank you
  2. May 4, 2019 at 8:17 PM
    huzer
    huzer Well-Known Member
    Tim
    CO
    2019 4Runner
    I have a ‘19 4Runner, no vibration issues at all in 7k miles.
    BrokenMech likes this.
  3. May 6, 2019 at 5:09 AM
    Roody
    Roody Well-Known Member
    Ross
    SW CT
    GX460
    Have an '18 and have spent a ton of time on the dedicated T4R forums, only vibration issues seem to be when people start modifying their suspension and something doesn't go as planned
  4. May 6, 2019 at 7:47 PM
    JCOOR
    JCOOR Well-Known Member
    TRD Burglar
    About 14k fairly rough miles on my ‘18 and zero issues or complaints. They drive much better than the Tacoma
  5. May 6, 2019 at 7:53 PM
    WhiteTaco19
    Sin City
    2019 T4R TRD OR
    Agreed. I purchased mine Saturday. Love it.
    I am however having slight brake pedal pulsation while braking, and a steering wheel wobble at 60mph that seems to be common in the 5th gens.
    Can't catch a break I guess.
    But even with these issues, it's a lot more enjoyable to drive than my Taco. Engine and transmission is super smooth.
    Hoping its an easy fix. The wobble goes away when the tires warm up.
  6. May 6, 2019 at 7:59 PM
    JCOOR
    TRD Burglar
    Most likely a tire issue. I ran KO2s for about 10k and they would never balance. I just traded them back in towards some ST MAXX and it’s driving perfect
  7. May 6, 2019 at 8:05 PM
    WhiteTaco19
    Sin City
    2019 T4R TRD OR
    Yeah I am hoping.
    I took it to my buddies tire shop today. He road forced balance one tire and it was slightly off, the second one was out of round he said. Unfortunately his machine went down and couldn't compete the balance.
    I will go back when hes get it's working again and get a full report from him and take it and show it to Toyota dealership.
  8. May 6, 2019 at 8:14 PM
    JCOOR
    TRD Burglar
    You should be able to get Toyota to warranty a tire if it’s bad or just upgrade them
  9. May 6, 2019 at 8:32 PM
    WhiteTaco19
    Sin City
    2019 T4R TRD OR
    Yup, once I get the full report from my buddy I will.
    How are the brakes on yours? I get a slight pulsation and also the brakes seem to be horrible in general.
  10. May 6, 2019 at 8:42 PM
    JCOOR
    TRD Burglar
    I honestly have no complaints about the vehicle. It doesn’t live the easiest life and has been flawless
  11. Jul 18, 2019 at 2:06 PM
    TRDPro916
    TRDPro916 Well-Known Member
    TRD
    None
    Issues I've had with my Taco Pro was noise coming from passenger pillar rubbing on dash. It was a easy and quick fix. The other issue was my AC noise, which is currently at the dealership getting replaced and still making noise. I've been checking on the 3rd brake light, a lot of people had issues with water leaks.
    Hope my new 19 4Runner Pro has less issues. I don't think I've ever own a new or newer car that didn't have some sort of problem.
  12. Jul 21, 2019 at 6:38 PM
    anotherreject
    anotherreject Well-Known Member
    2018 with 40k miles, no complaints
  13. Aug 28, 2019 at 5:18 PM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    you have an off-road, the pulsation you describe, is it just the momentary buzz when applying? The off-road and pro have crawl control, so there is a slight buzzy feel in the brakes occasionally -it's the brake booster. the 3rd gen Tacoma I had did the same, but it was much more pronounced. the t4r is quite muted compared to the Tacoma.
  14. Aug 29, 2019 at 6:33 AM
    bcstaco5
    bcstaco5 Active Member
    Raleigh NC
    2019 TRD Off Road Limited
    Just traded my 19 Taco for the exact reason. Bad vibration at low speeds. Dealer performed TSB which was stiffer leaf springs and steering damper...it was 100x worse. Can't believe they even let the truck leave the lot like that.
    4Runner is light years better IMO. Drives smoother and rides better. Powertrain is a better combo, no more fall-on-your-face shifting for no reason. Better torque so it actually holds a gear. Premium interior is higher quality. Hoping to keep the 4runner for awhile. Was not impressed with the taco.
    camillethetoy and Riding Dirty like this.
