Interested in parking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Skydvrr, Oct 1, 2020.
Pull in, back in, depends?
  1. Pull in
  2. Back in
  3. Depends
Results are only viewable after voting.
  1. Oct 2, 2020 at 5:44 AM
    #41
    Tacospike
    Two Trucks
    Pull out :confused:
    Kev250R and 71tattooguy like this.
  2. Oct 2, 2020 at 5:45 AM
    #42
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Same as you, Op. I back in unless the parking is slanted. I used to suck at driving in reverse because I rarely ever did. So I decided I would start doing it one day. Now, I do it all the time.
  3. Oct 2, 2020 at 6:05 AM
    #43
    Kilwager
    Kilwager Member
    Tom
    Massachusetts, North Shore
    '06 SR5 Dbl Cab, 2" lift, ARE cap
    I always back in at home. I have an '06 with no rearview camera. With a cap on the back, you're trying to look through 2 layers of tinted windows which, in the morning when it's still somewhat dark, makes it difficult to see. Even worse if there's condensation on the cap-windows, which there often is.
    If you go nose-in, when you get in your vehicle, in the time it takes you to adjust the radio, send that last text message, adjust the temp, etc... someone out for a walk could have made their way down the street, and now they're right behind you. Or even worse, a little kid.
    Plus I often use my tailgate as a workbench-of-sorts because it's right by the garage door.
  4. Oct 2, 2020 at 6:46 AM
    #44
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Parking.....is a different world.
    I learned to make a left turn into a head-in parking place. The left turn allows more space for the longer wheelbase. I rarely if ever make a right hand turn into a parking spot.
    This was a lesson taught by a '71 Buick Electra 225, my college ride. That ride was bigger than most pickups. The door handles would span the width of a parking spot. OMG, the doors were about 6 feet long, many times the door would barely open enough to get out. With the wheels tight against the tire stop, the 225 was long enough to extend beyond any surrounding vehicle.
    Typically, I head-in park because I need access to the tailgate to load the materials I just purchased.
  5. Oct 2, 2020 at 6:58 AM
    #45
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    I see people backing in not stopping until the tires hit the cement stop or fall off the pavement and overhang three feet into the grass, what about those that have to mow and weed wack... Those in a sports car pulling into a space and not stopping until the tires hit the cement stop all the while scraping their low slung spoiler...
  6. Oct 2, 2020 at 7:05 AM
    #46
    nmum
    nmum Well-Known Member
    I started backing in with my previous truck that had a large turning radius and no rear view camera. Before that I didn't really have experience with back in parking and my brother in law had to give me tips about it.
    In our previous parking lot the street was really narrow due to cars parking at the curb in front of the parking spot.
    That and other narrow lots, would sometimes require like 16 point turns to get out backing out.
    It's funny how some areas issue tickets for it. One of our previous neighbors mentioned that they thought we were government workers because some agencies require cars to be parked by backing in. And it's been a while, like twenty years, since I've been there but there was a place with a busy nightlife in our area that required backing into the metered parking spaces.
    But I'm kind of opposite of others where the main times that I do front end parking is when I need access to the bed to load/unload something. Or maybe if I'm in a crowded parking lot with a car right behind me. But other then that I mostly do back end parking.
    btw OP, in regards to what you said about some people taking the spot if you go a few feet in front of it, sometimes when I do decide to back in in a crowded parking lot where people are fighting for spaces, I sometimes try to make my intentions clearly known by making sure to use signals (I usually do that anyways) but instead of going straight pass it, I immediately pull into an angle to get ready to go in and try to hit reverse as soon as possible, so they see the reverse lights. Sometimes you still have pricks that take the spot but usually people that see what you're trying to do gives you room and some people even reverse to give you more room.
  7. Oct 2, 2020 at 7:11 AM
    #47
    canyonchaser
    canyonchaser Member Known Well
    Dave
    Utah
    LR TRD PRO MT
    I always look for pull-through parking locations. Even if that means I have to walk a little further to get to my destination.
    • A) I still get to move forward on my way out.
    • B) I get to avoid going backwards where visibility is limited - but it's all about C.
    • C) Putting an AT from Drive to Reverse is the moment when it sees the most wear, so by not going from D to R, I'm "saving a shift" for future me.
  8. Oct 2, 2020 at 7:18 AM
    #48
    Skydvrr
    Skydvrr [OP] IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Annnnnd backing in wins. Backing in just seems so much "safer"
    Tacospike likes this.
  9. Oct 2, 2020 at 7:20 AM
    #49
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Back OUT OF traffic, drive IN TO traffic. Simple really.
  10. Oct 2, 2020 at 7:21 AM
    #50
    tirediron
    Ummm... why?
  11. Oct 2, 2020 at 7:24 AM
    #51
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Hmmm. Parking. In front ways or back ways all depends on the girl.
  12. Oct 2, 2020 at 7:36 AM
    #52
    KingJeff813
    KingJeff813 Well-Known Member
    Wisconsin
    2020 Alfa Romeo Giulia Ti Sport Q4
    Traded it in.
    I always back in...unless I'm in one of those parking garages that say "No backing in to stall". Which hasn't been an issue with the Taco but my old F150 caused me to block traffic while making my 20 point turn trying to back out a few times given how narrow the whole thing is.
  13. Oct 2, 2020 at 7:48 AM
    #53
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Back in and back it In slowly
  14. Oct 2, 2020 at 7:50 AM
    #54
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    I always back in, utilize the camera so it makes it easier to pull out of parking spaces, also park in the garage so with it being tight, its easier with a camera.
    As always, pull out when necessary
    Skydvrr[OP] likes this.
  15. Oct 2, 2020 at 7:55 AM
    #55
    Cementing
    Cementing Well-Known Member
    2019 Tacoma TRDOR Cement
    That sounds nice, every time I park I back in, and by the time I swing out to position myself to back in the genius behind me is only a few feet away from my rear bumper. I can't tell you how many times I've had to give up on a spot and move on to something else because people follow too closely. :annoyed:
  16. Oct 2, 2020 at 8:03 AM
    #56
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Exactly People suck
    Vmax540 and Cementing[QUOTED] like this.
  17. Oct 2, 2020 at 8:27 AM
    #57
    Professor D
    Professor D Ex retired lion tamer
    Gregorny
    Mass
    2019 Toyota Tacoma race car
    Yes
    I do tree work and we work for the state highways/railways/Right if ways any how it’s company policy to only back vehicles in for the same reason too many accidents and what not
  18. Oct 2, 2020 at 8:34 AM
    #58
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Its happened once or twice to me. I just sit there with reverse lights and turn signal until they back up and give me room.
    71tattooguy likes this.
  19. Oct 2, 2020 at 9:30 AM
    #59
    71tattooguy
    Dino
    Petaluma , Ca (707)
    LMAO!!
    Skydvrr[OP] and Rock Lobster like this.
  20. Oct 2, 2020 at 10:43 AM
    #60
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I love it when that happens. I just continue on my merry way backing in, even if I'm inches away. Some car kept honking at me in a garage once cause she thought I was gonna hit her. I leaned out the window and said “I see you! Don’t worry, everything’s gonna be fine” I think it took her by surprise.
