Interested in the Trailhunter but need Running boards more than rock rails
Discussion in '4th Gen. Tacomas (2024+)' started by packfan, Nov 16, 2023.
  1. Apr 12, 2025 at 2:48 AM
    BaltimoreMD
    BaltimoreMD Well-Known Member
    4gen Taco Ltd HV
    You'd have some dash button work cut out for you putting LTD's auto running boards on a TH.
    I'd suspect the physical install of the motor and boards to be reasonable, but there are only two rectangular dash button positions, and when you examine setups and parts diagrams the same location is used for the LTD step controls and the TH multi-color fog controls. There is no other equal sized blank in the truck.
  2. Apr 12, 2025 at 8:25 AM
    TH_Don
    TH_Don Active Member
    2024 Bronze Oxide Trailhunter LWB
    N-Fab makes bolt on steps which I have on my Trailhunter (bought two sets of two) - make it easier to step in/out plus blocks some of the crap thrown off the front wheels. Installs and removes in a few minutes (two bolts each step). That is the Canadian price shown on Amazon.Ca (U$ price is much lower).
    Screenshot 2025-02-02 171831.png Screenshot 2025-02-02 171907.png Screenshot 2025-04-12 092233.png
  3. Apr 12, 2025 at 6:12 PM
    Surfncamp
    Surfncamp Member
    2024 Tacoma Trailhunter 6' bed
    TH Don are these compatible with the stock Trailhunter rock rails? I assume so but just checking. Was drilling required?
  4. Apr 12, 2025 at 7:15 PM
    TH_Don
    Yes direct bolt-in onto stock Trailhunter rails with no drilling, lines up with the holes already in the gussets between the inside and outside tubes. I’m assuming they would also directly bolt into the 5’ bed rails but I have the 6’ bed.
  5. Apr 12, 2025 at 8:11 PM
    Surfncamp
    Surfncamp Member
    Thank you TH Don. I will order some soon!
  6. Apr 12, 2025 at 8:33 PM
    MGMDesertTaco
    I liked that the rock sliders were tucked up on the trailhunter, so you don't catch your feet getting in and out. :notsure:
  7. Apr 13, 2025 at 8:49 AM
    TH_Don
    They line up better in front of or behind the gusset depending on which side of the vehicle you're on if I remember correctly, they fit better if they don't press up against the fillet welding between the gussets and the tube on the OEM sliders. You also have to tighten them up a bit to suck them in as close to flush as possible against the gussets.
  8. Apr 14, 2025 at 12:00 AM
    wfxt
    wfxt Well-Known Member
    The Empire State
    2025 Underground THLB (2021 MGM T4R Pro)
    That’s really interesting, Don.
    Do you account for the steps actually blocking a significant part of the debris spray from the front?
  9. Apr 14, 2025 at 6:12 AM
    TH_Don
    When I was driving in snowy conditions there was quite a build up of snow on the front plus bottom sides of both the front and rear steps leaving less on the rear fender so it's definitely blocking some of what's coming off of the front wheels - how much I can't say.
    Currently I also replaced my Canadian Trailhunter mudflaps with the RallyArmor ones which hang down a couple of inches lower too.
  10. Apr 21, 2025 at 5:41 PM
    wfxt
    The Empire State
    Is this the same you reckon, Don?
    not N-Fab but RKR yet the same part number…
  11. Apr 22, 2025 at 6:34 AM
    TH_Don
    Looks the same and both identify as a RealTruck item so assuming they're the same but just sold through different channels/distributors? My NFab ones say "NFab" in the middle of the top surface and aren't fully dimpled like shown in the Amazon photos (fully dimpled would probably be better for shoe grip anywhere on the step but I've never had any issues with my foot slipping either in wet or snowy conditions).
  12. Apr 23, 2025 at 9:40 AM
    codeblue!
    codeblue! Well-Known Member
    Codeblue
    2019 OR sold, 2021 OR, 2023 OR, 2025 TrailHunter
