Interesting Alignment Problem After Changing Camber Hardware and LCA Bushings
Discussion in 'Suspension' started by Drunknsloth, Oct 22, 2013.
  1. Oct 22, 2013 at 1:47 AM
    Drunknsloth
    Drunknsloth [OP] Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    SCROLL DOWN FOR PICTURES
    I have an alignment problem that I can't figure out. I just barely replaced my LCA camber bolts, sleeves, and everthing including the bushings because they seized and I couldn't get an alignment anymore. I checked all the alignment tabs and nothing is bent. I do have the Bilstein 5100 Adjustable shocks set at 0" with OME 885 coils on the front. I know that some people needed new UCA's after a lift to get a proper alignment but when I first lifted the front Firestone didn't have a problem aligning it.
    My most recent numbers before the Camber Sleeve seized:
    Code:
              Left    Right  Factory Range
    Camber:   1.1     0.8    0.2-1.3
    Caster:   1.5     1.3    1.0-2.5
    Toe:     -0.01    0.03   0.0-0.11
    Some time later my camber sleeves seized inside the bushing and Firestone was unable to adjust it. I tried getting it aligned again a little while later again after soaking it in PB blaster but that didn't help either. (I also got Spidertrax spacers while the sleeves were seized, but I don't think that should affect the alignment). I cut out the bushings and camber sleeves recently and had the Toyota dealership push out my old bushings and press in my new ones and I put everything back together. I then got an alignment and my numbers are:
    Code:
    Camber:   0.5    [COLOR="Red"] -0.7[/COLOR]   0.2-1.3
    Caster:   2.0     [COLOR="red"]0.4[/COLOR]    1.0-2.5
    Toe:      0.01    -0.01  0.0-0.11
    Both the cams on my right side are maxed out with the bolt towards the center of the truck and the tab facing outwards. My front left cam is also maxed out with the bolt towards the center of the truck and the tab facing outwards. My back left cam is pretty neutral.
    I didn't change my suspension in any way between the two alignments except for the camber bolts. What could be causing this problem? Could it get worse? Or should I just get new UCAs and hope that solves the problem? Will new UCAs give me too much Caster on the left side?
  2. Oct 22, 2013 at 5:57 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    You take any real hard hits?
  3. Oct 22, 2013 at 6:17 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Do you trust the alignment shop? Those numbers seem pretty screwy, almost like the tech screwed something up...
  4. Oct 22, 2013 at 6:26 AM
    JohnnyWayne
    JohnnyWayne The Past Through Tomorrow
    Johnny
    Lantana, FL
    '12 DCLB TRD Sport
    Look out for snakes in the grass guerrilla marketing.
    What Pugga said, those numbers look really wacky :confused:
  5. Oct 22, 2013 at 8:33 AM
    Drunknsloth
    Retribution
    South West
    I took one really hard hit once on the passenger side when the bolts were seized but they got the alignment pretty close with the bolts seized but they didn't give me the paper. Is there a part I can check to see if that screwed something up?
    Not really. I used my lifetime alignment at firestone. I brought it in at noon and they didn't get to it until closing time so the tech might have been in a hurry. Maybe I should take it to another one?
  6. Oct 22, 2013 at 8:45 AM
    Drunknsloth
    Retribution
    South West
    I'm not really knowledgeable about alignments. How do you know if the numbers are screwy?
    I'm thinking since my cams are pushing my LCA maximally inwards, can't I just turn both of them a slight bit and get me to optimal camber?
    Right now my truck goes straight when the steering wheel is straight. It doesn't seem to pull to hard either way. But the steering wheel shake gets crazy around 40 to 50 mph.
  7. Oct 22, 2013 at 10:14 AM
    Taco'09
    Taco'09 Well-Known Member
  8. Oct 22, 2013 at 10:53 AM
    JohnnyWayne
    Johnny
    Lantana, FL
    '12 DCLB TRD Sport
    ^^ I'm not that great with alignments either but there is a MASSIVE difference between left and right caster so that looks screwy to me, if both sides are mirror images of each other they should be able to get those caster numbers close, if not then I would think that something is either wacky with the tech or possibly something is bent as Taco09 said. I'm no expert but sumthin aint rite :)
  9. Oct 22, 2013 at 10:58 AM
    Pugga
    Massachusetts
    F-150 Mod
    You can tell the numbers are screwy because they're soo far apart side to side. I had my numbers that far off once and it was because one side was seized and the tech told me he couldn't budge anything on one side of the truck. With everything being new and free, there's no reason to have that kind of difference side to side unless something is bent.
    I would take it back to Firestone first and tell them to fix it. At the very least, they should have given you an explanation as to why the numbers were that far off.
  10. Oct 22, 2013 at 11:11 AM
    Drunknsloth
    Retribution
    South West
    Do shops usually check the numbers for free? Or should I try to use my lifetime alignment on another firestone?
    It'll suck if it's a bent lower control arm. I just spent a bunch of money on the OEM bushings (and having them pressed in) that come with the LCA if I just bought that instead...
  11. Oct 22, 2013 at 11:16 AM
    Drunknsloth
    Retribution
    South West
    The service manager that gave me my keys back just told me the tech said it looked like something was tweaked. I'll probably hit up another firestone and see what they say. I don't remember my LCA looking noticeably bent when I took it off... I'll check again when I get out of class.
    Would just getting new UCAs if my LCA is bent fix the problem? Or is that not safe?
  12. Oct 22, 2013 at 11:30 AM
    Pugga
    Massachusetts
    F-150 Mod
    If your LCA is bent, the best possible solution is to replace it. An adjustable UCA might help your alignment, but I'd fix the problem, not find a work around.
  13. Oct 22, 2013 at 11:34 AM
    Drunknsloth
    Retribution
    South West
    Hmmm... yeah that makes sense. I'll be able to check in about two hours.
  14. Oct 22, 2013 at 2:15 PM
    Drunknsloth
    Retribution
    South West
    Okay so the LCA doesn't look bent, the spindle doesn't look bent, and the UCA doesn't look bent. There are some pictures below, I might be missing something.
    Firestone is really starting to irk me. Since I've gotten the truck I've had it aligned 5 times. The first two and the most recent one by one firestone and the third and fourth time by another firestone. It looks like they're doing a really good job of rounding off my rack ends for adjusting the toe as you can see in the first picture (nice and shiny) :mad:
    Here is the right (bad alignment side) LCA and it shows the rounded rack end:
    Here is the left (good alignment side) LCA:
    Here is the right (bad alignment side) Spindle:
    Here is the left (good alignment side) Spindle:
    Here is the right (bad alignment side) UCA:
    Here is the left (good alignment side) UCA:
    The following pictures of the Cams are all looking from the rear to the front, so all the pictures are looking at the rear of the Cam
    Here is the right (bad alignment side) rear Cam:
    Here is the right (bad alignment side) front Cam:
    Here is the left (good alignment side) rear Cam:
    Here is the left (good alignment side) front Cam:
  15. Oct 22, 2013 at 3:22 PM
    Drunknsloth
    Retribution
    South West
    It looks like my right side toe is also maxed out... :confused: I'm completely stumped
  16. Oct 22, 2013 at 3:44 PM
    XXXX
    sKiP
    05 Prius
    I don't see the LCA bending before the mounts do. Once the lca is removed you can bend the paperthin mounts by hand. Check where they are welded to the frame. If you don't see cracks I guess you could of bent the lca but still find it very very hard to believe. If it is bent they are going for $350 new per side with New bj's and bushings.
  17. Oct 22, 2013 at 4:41 PM
    Drunknsloth
    Retribution
    South West
    I just went out and looked. This is a picture of the weld on the rear side of the front passenger LCA/Cam mount (Looking at the lower side of the weld in this picture, the lower side is the side against the actual mount and the upper side is the side against the frame):
    I can't tell if it's paint flaking off or a crack in the weld. I know it's a big problem if it's a crack but it doesn't look like it would have moved enough to screw up my alignment this bad would it?
    And if it's a crack how would I fix it though? I mean if I just weld it on as is then my alignment is still out of whack.
    I will do that before I start changing parts. I'll have to wait until this weekend though because classes are really killing me. :eek:
  18. Oct 22, 2013 at 4:52 PM
    Pugga
    Massachusetts
    F-150 Mod
    Camelback Toyota has LCA's for $230 if I recall correctly :)
    That bad rear tab should be the other way, that would push the rear out helping your camber number and push the spindle forward helping your caster number. If your LCA isn't bent, it could just be a shitty alignment job.
    Keep in mind, if your LCA is visually bent, you have serious issues. You're talking about a couple degrees of variation. A slight bend in the LCA would be tough to spot with the naked eye.
    A crappy alignment job or a bent LCA could both be the culprit.
  19. Oct 22, 2013 at 4:58 PM
    Drunknsloth
    Retribution
    South West
    So here's what I'm thinking, I should turn the tab a slight bit like Pugga described and then try to take it to another shop for another alignment and see what they say.
  20. Oct 22, 2013 at 5:17 PM
    Pugga
    Massachusetts
    F-150 Mod
    Like Ashiet said, I wouldn't mess with anything. I'd let an alignment shop do the dirty work. If you turn it yourself, you'll know generally what you did, but you could mess with toe and camber which can chew up your tires.
