Interesting read on gear oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Demfer, Sep 14, 2020.
  1. Sep 15, 2020 at 8:59 AM
    #41
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I can only hope my Tacoma is that reliable!
  2. Sep 15, 2020 at 9:03 AM
    #42
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    While i wouldn't use wally world's super tech oil in my latest truck, i found it's more than ok to use in my outboard motors, older snowmobiles, and power equipment.
    tonered likes this.
  3. Sep 15, 2020 at 9:04 AM
    #43
    zoo truck
    None
    Do not say that...it better be.
  4. Sep 15, 2020 at 9:35 AM
    #44
    Aardvark13
    Aardvark13 Sultan of Squeeze, Wizzard of Slide
    Byl
    Knoxville
    2014 DCSB OR
    Aardvark4x4 Built for Go
    I just bought one to do my Tranny. I been restoring a flooded FJ Cruiser and did a trans fluid flush, ended up running 15 qts through it with a hand pump(made my 17 yo kid pump most of it lol) and that really pushed me to get a sprayer for doing the Tacoma.
    tonered[QUOTED] likes this.
  5. Sep 15, 2020 at 9:37 AM
    #45
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    I have two old pump up sprayers out there in the shop. Been hanging on to them since I got the backpack sprayer, knowing something would come up and I would need them. It just came up.
    tonered likes this.
  6. Sep 15, 2020 at 9:45 AM
    #46
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Oof! That is a lot of pumping.
    The FJ keep looking better as time goes on. Enjoy it!
    :D Glad that I could help.
    @MtnFisher and I were kicking around the idea a while ago. He got the first crack at it:
    I'm thinking of adding a pull through schrader valve with no core to allow a compressor to drive it at very low pressure. Just pulling the chuck should relieve the pressure and stop the flow.
    MtnFisher likes this.
  7. Sep 15, 2020 at 10:09 AM
    #47
    Aardvark13
    Byl
    Knoxville
    2014 DCSB OR
    Thanks, I am almost there!
    Same one I bought.. now that things are starting to cool off a little I will be playing around with this too.. I like the compressor idea..
  8. Sep 15, 2020 at 10:35 AM
    #48
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice work. It looks like you scored on that FJ.
    You're welcome! Post up how the sprayer works for you.
    :cheers:
  9. Sep 15, 2020 at 11:07 AM
    #49
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
  10. Sep 15, 2020 at 11:11 AM
    #50
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  11. Sep 15, 2020 at 11:16 AM
    #51
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    No pumping. I mean, ya can if ya want to. I also like the shut-off valve. I also don't have the time to be fabbing stuff. I have three cars to maintain; two of them with a lot of miles on them. Not saying y'alls solution doesn't work, but have you tried the transfer case with it, or the front differential? Or the transmission (ew). Asking seriously. I bought one of the Motives for a specific car; never thinking I'd use it much. But it keeps coming in more and more handy as space becomes more and more limited underneath.
  12. Sep 15, 2020 at 11:26 AM
    #52
    Aardvark13
    Byl
    Knoxville
    2014 DCSB OR
    Yeah
    Yeah I know, lol.
    I was actually tempted to get this one, but is even more expensive. https://smile.amazon.com/dp/B01HLVQ...colid=K3I1WSKQUHJX&psc=1&ref_=lv_ov_lig_dp_it
    I will probably only use mine for the transmission since everything else is so easy, so I thought it would be fun to make the $10 one work.
    tonered likes this.
  13. Sep 15, 2020 at 11:27 AM
    #53
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is what I meant by removing the core of the valve. As soon as you remove the compressor air (just a few PSI max), the flow would stop. @MtnFisher was pretty happy just using the wand control that came with the sprayer and the hand pump. Just not using the spray tip.
    Three cars and a bike here. Hoping for a second bike. :D The Taco is our only vehicle with serious driveline fluids.
    For the T case, I used Ravenol. Genius bottle with a straw spout. Easily got the entire liter in. On the next round, I may use the Toyota LF fluid in a can with the small hand pump cleaned very well.
    Front diff is no problem with the length of sprayer hose provided.
    MT here. With just a couple quarts needed, I may use the hand pump there also. I don't see a need for two sprayers. If I had an AT with the larger capacity and more frequent swaps, a second sprayer might make sense, esp if the other cars used the same fluid?
  14. Sep 15, 2020 at 11:27 AM
    #54
    Bryanccfshr
    Bryanccfshr Well-Known Member
    2018 Trd OR , 2018 TRD Pro 4Runner
    The only time I replace my diff fluid frequently was when I used to cross water a lot as a precaution. The differential fluid doesn’t get hot enough to oxidize and if you don’t flood the breather with water Or you aren’t rock crawling with extreme shock loads happening the fluid and additives will continue to work for a very long time.
    I might change mine at 50k. If I choose a synthetic it isn’t because it performs better At protecting the gears, it is because it will thicken less when cold and help overall economy.
    tonered likes this.
  15. Sep 15, 2020 at 11:31 AM
    #55
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Cool. Cool. I've owned a lot of German vehicles, so I'm a right tool for the job type. And at times there wasn't a choice. I have a cabinet of tools solely for those experiences. That little pump thing really helped with doing the transmissions on a lot of VWs, a Ford, and now the Tacoma. I also can't stand the odor of gear oil! :D
  16. Sep 15, 2020 at 11:33 AM
    #56
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    That thing's nice! It can suck AND pour! I don't think I would have ventured into that cost-level!
  17. Sep 15, 2020 at 11:37 AM
    #57
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah. Gear lube is not pleasant. But, you'll be thankful there is only one liter of T case fluid to mess with.
    BTW, don't be in a rush to change the T case fluid. Mine came out looking virgin at 7k while truly using it from time to time and always getting the exercise in if not using it enough. I'd say 60k on the first swap there?
    davidstacoma likes this.
  18. Sep 15, 2020 at 11:40 AM
    #58
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Yup. Lazy part of me would rather not change anything at all. Especially with skid plates. I should hit the 60k mark by the weekend and I have all the fluids lined up and ready to go. I did the rear already because I had to pull an axle to fix a boo boo. Went with all Redline for no other reason than history with it.
    davidstacoma and tonered[QUOTED] like this.
  19. Sep 15, 2020 at 11:43 AM
    #59
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It just depends on how long you are going to hang on to it. If I was swapping on a regular basis, it would be whatever the OM says with the less expensive stuff that I could use. Since I'd like this to stay around for 20yrs, I'll get in there one the severe duty schedule.
    I have only heard good things about the RL diff lubes. Their MT lubes have fixed shifting issues and make them a lot slicker.
  20. Sep 15, 2020 at 11:46 AM
    #60
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    I'd like to keep the truck until it pukes. We'll see if that happens. I have issues.
    Yeah. Redline manual transmission fluids are what sold me on them a long time ago. It made some borderline crappy transmissions much better.
