Interference with head unit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bobbyds1, Apr 14, 2025.
  1. Apr 14, 2025 at 5:17 AM
    bobbyds1
    bobbyds1 [OP] Well-Known Member
    Bob
    2013 tacoma base
    I am having a situation with a head unit looking for help. I purchased a Kenwood DMX809 head unit the problem i am noticing is when i turn the key to ACC all my radio stations come in crystal clear as soon as i turn the key to the on position engine not running just the key in the on position i loose the radio stations its like someone unplugged the antennae. same if i start the engine. has anyone ever have this happen. does anyone know what turn on when the key is in the on position could be causing interference with reception.
    I tried swapping out the head unit 3 times all do the same thing any help would be appreciated.
  2. Apr 14, 2025 at 3:35 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Do you have any other aftermarket electronics installed? Poorly shielded LEDs for example can screw with things.
  3. Apr 14, 2025 at 4:38 PM
    bobbyds1
    Bob
    2013 tacoma base
    No nothing
