Interior Build Quality 2016 SR5
Discussion in '3rd Gen. Tacomas (2016-2023)' started by enominezerum, Nov 18, 2015.
  1. Nov 19, 2015 at 4:23 PM
    busticator
    busticator Well-Known Member
    FL
    2016 Tacoma SR5 DCSB
    CPS rev2
    I've cleaned my interior with paper towels a few times now and don't see any scratches. LOL. Can you get this in a pic? Maybe I'm not critical enough... I think the interior is pretty nice, seems well put together, and seems relatively rugged to me. Nice change in textures, which is cool for a pickup in my opinion. I probably wouldn't sweat the scratches unless they mess with visibility in the instrument cluster, and maybe don't do again whatever you did in the past.
    And yes, I think my sound system is bass heavy for FM radio, I have it turned down a couple of notches and seems a bit more neutral sounding. For XM radio, it seems the mid control needs to be turned down a notch to sound better. It seems like the output is limited for volume, but I could see how on default settings you could blow out a speaker with some boom boom music.
  2. Nov 19, 2015 at 5:30 PM
    LuvTacos
    LuvTacos Well-Known Member
    Can't say I've seen this in any of my previous vehicles, especially the 35K+ ones. I like your idea, tell the dealer to order you a 10 pack and get it replaced every time you clean it.
  3. Nov 19, 2015 at 7:07 PM
    Tuck91
    Tuck91 Well-Known Member
    2014 Toyota Tacoma Regular Cab 4x4
    My 2014 has light hairline swirls & my 2016 is even more sensitive. Its n ot us its the material Even the softest microfiber scratches.
  4. Nov 20, 2015 at 9:47 AM
    enominezerum
    enominezerum [OP] Dreamer
    I'm not bothered by the negativity. I have been touching tech and things far more delicate for over 15 years. The reason this surprised me was because it scratched far easier than the Yaris. That I'm not they only one that had experienced this sets me at ease a bit.
    As for the scratches I'll get over it. A deer already hit me and I feel that a truck should used for as a truck, not a pristine show vehicle. Heck I have already scratched the bed and put wear on it.
  5. Nov 20, 2015 at 9:56 AM
    robertbank
    robertbank Well-Known Member
    Bob
    Terrace, BC
    Ordered TRD Sports DCLB Upgrade Pkg
    You what???? :D Would that be under warranty????;)
  6. Nov 20, 2015 at 9:59 AM
    busticator
    FL
    CPS rev2
    Don't think people are being negative... depending on where they are and the depth, scratches would probably piss me off. Not seeing the issue with mine, but I might not be looking close enough. Like I said, I'm basically using windex and papertowels on the plastic. Might be bad, dunno, but I've done it before and had interiors that looked brand new on 10+ yr old cars.
  7. Nov 20, 2015 at 10:04 AM
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    If the truck scratches from small amounts of dust then its not built to be a truck but a pussy mobile.
  8. Nov 20, 2015 at 10:06 AM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Also in addition to using a clean microfiber, I would recommend using some sort of cleaning chemical to "lubricate" the surface. It will not only clean the cheap plastic but also keep from scratching. I use a really expensive LCD/LED screen cleaner. Same stuff I use on my UHD TV
  9. Nov 20, 2015 at 10:07 AM
    gromit615
    gromit615 Well-Known Member
    Eric
  10. Nov 20, 2015 at 10:09 AM
    enominezerum
    But that will hold dust and dirt, thought we were using compressed air and a vacuum at this point.
  11. Nov 20, 2015 at 10:13 AM
    gromit615
    Eric
    Try it, perhaps? Shake it out afterwards? With such a light contact to the panel I doubt that it would damage it (further). Its not a scrubber... just a quick pass
  12. Nov 20, 2015 at 10:17 AM
    robertbank
    Bob
    Terrace, BC
    You could always tape plastic over the whole dash and let the dust settle on the cover. The only potential problem that might arise would be getting the tape adhesive off the dash. Perhaps surgical alcohol could be used on the adhesive. Just saying.
    enominezerum[OP] likes this.
  13. Nov 20, 2015 at 10:29 AM
    Trump16
    Trump16 Active Member
    Wallace
    This. Toyota's main advantage in the market is QDR; you're trashin it!
  14. Nov 20, 2015 at 1:31 PM
    dutchjim
    dutchjim Well-Known Member
    Jim
    San Diego
    I googled 'removing scratches from clear plastic instrument panels'. Jeep, GM, Toyota, Ford, Chevy and others had this problem. It seems to be more of an issue with year 2000 and up.
  15. Nov 21, 2015 at 9:35 AM
    #35
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    You get any useful information on how to de-scratch?
  16. Nov 21, 2015 at 9:43 AM
    #36
    mykaelp
    mykaelp Well-Known Member
    Michael
    Oregon
    2016 Tacoma TRD Off Road DC SB Quicksand
    Any speaker will blow if you pump enough distortion through them. I doubt the base speakers are very high quality nor the amp pushing them. Once you get distortion coming through, dial the volume back. That being said, pretty sure warranty will cover it, with a lecture from whatever dealership you go to.
    The JBL system distorts fairly easily, depending on what I'm listening to.
    Good luck.
  17. Nov 21, 2015 at 9:51 AM
    #37
    mykaelp
    Michael
    Oregon
    Maybe I missed it, but can you post pics of the scratches? Unless they're terrible, I'd say it's fairly common amungst all brands. Cheap plastic is the norm these days. I use soft microfiber and windex, and all of my vehicles have had superficial scratches. I'd say get over it.
  18. Nov 21, 2015 at 9:55 AM
    #38
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Ever-increasing interior technology is what sells these days, so automakers are making other components way more cheap and flimsy to keep costs down. It's not just Toyota. I have a 2014 F-150, it only has 11,000 miles on it, and I have cleaned the instrument cluster exactly one time with the microfiber cloth that came with the truck. I took it straight out of the packaging, wiped the "glass" as delicately as you'd wipe a premature baby's nose, and I can already see fine scratches. AAAAARRRRGGGGHHHH!!!!!! I don't fucking care about bluetooth, touch screens or power folding mirrors. I just want shit to last.
    Shelf Life and enominezerum[OP] like this.
  19. Nov 21, 2015 at 10:07 AM
    #39
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    yea i posted earlier,i put some scratches in my cluster. i'm trying to get over it, there not really that bad ,but. i will take alot more care from now on, get some more "special" cleaning gear. will try to polish out in the spring, winter moved to michigan today. my 15 is black so i'm on a learning curve. o.c.d. is a pain in the ass. my 02 was silver, you could dry that thing with sandpaper and it would'nt scratch. i took black, but got a great deal.
  20. Nov 21, 2015 at 1:52 PM
    #40
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    What next, aftermarket screen protectors like people use on their mobile phone screens?
