Interior courtesy lights
Discussion in 'Lighting' started by jdumas54, Jan 27, 2009.
  1. Jan 27, 2009 at 8:34 PM
    jdumas54
    jdumas54 [OP] Member
    Northwest lower Michigan
    Impulse Red Pearl 4X4
    Modifications? Umm, I got those little convex mirrors attached to the side view mirrors...
    Just wondering, if any of the Tacoma models have dash operated interior lights? I so miss being able to light up the cab, by rolling the guage dimmer switch.(like on most vehicles I have owned) It is a pain having to reach up behind me and fiddle to find the ceiling light switch just flash the interior light on for a few minutes.
    Has anyone added a feature like this to cabs without this option? I would think adding lamps under the dash would be possible.
    if this has already been addressed, I apologize...
  2. Jan 27, 2009 at 10:49 PM
    chyknees
    chyknees nomadic wanderer
    So Cal
    05 Tacoma TRD 4x4
    TRD, Total Chaos, Fox, Volk, BFHoodrich
    Also curious about this.
    My friends new Tundra has a little amber led that is mounted on the front side of the center armrest. Thinking about trying to find that or just hit up Radio Shack for those little LEDS. But to put it on a dimmer switch would be even nicer.
  3. Jan 30, 2009 at 12:18 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K02 AT’s RCI skid Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    :confused:Not sure on the later models on how they are wired up, but what I did in my '03, was hook a wire from the dome light, to the map lights to get better light in there. These Dbl cabs just don't get much light from the wimpy dome lamp alone. Only one problem doing this. I modded the map lights to where both switches are on all the time because I wanted both the map & dome to come on at the same time, so I attached a wire from the door switch (& another wire to ground) then to a toggle switch by where the cup holders are. So now I just flip the switch when I want light. Before I put in this switch, I had to open up the door to light up all three lights.
