Interior Fuse Box Disassembly
Discussion in 'Lighting' started by 3JOH22A, Jan 6, 2024.
  1. Jan 6, 2024 at 12:15 PM
    3JOH22A
    3JOH22A [OP] トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Interesting disassembly video of the fuse box under the dash at 17:20:
    I suspect the owner put in a larger fuse (maybe 15A) when the original one blew.
    roundrocktom likes this.
  2. Jan 6, 2024 at 5:55 PM
    Chucky888_2021_TRD_OR
    Chucky888_2021_TRD_OR Live free and drive Taco
    Ching
    Osseo, MN
    2021 TRD OR DCSB
    He mentioned after market accessory, so not necessary a cheap one....
    Most likely used an add-a-fuse tap but it was more than 7.5A or not using a relay.....
    So, must know what you are doing with wiring and how much current draw before add to the truck.
  3. Jan 7, 2024 at 12:51 PM
    caribe makaira
    Caribbean, Puerto Rico
    Listen again to the video, he starts with turn signal not working and adding resistors. Then switches over to the parking circuit not working. Simple deduction is owner placed resistors on parking circuit, not on the turn circuit(s) wire(s).
  4. Jan 7, 2024 at 12:59 PM
    Ching
    Osseo, MN
    2021 TRD OR DCSB
    yes, good catch.
    Car-care nut just stated the cheap aftermarket accessory burn it up, in reality it is the wrong wiring of the resistor most likely did it.
    Does not matter how cheap or expensive the thing you added is, if you wiring it wrong it burn $hit up.
    caribe makaira likes this.
