Interior Latex Paint
Discussion in 'Garage / Workshop' started by teamfast, May 31, 2012.
  1. May 31, 2012 at 7:29 AM
    teamfast
    teamfast [OP] Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Flat
    Matte
    Semi Gloss
    Eggshell
    Gloss
    We have kids and want something that looks good and is washable without leaving wipe marks from cleanup. We used cheap paint and learned a valuable lesson last time.
    Have always used eggshell but have heard there is a trent towards using flat paint. I know Gloss inside is out of the question but I will roll it in the garage for water resistance.
    Discuss...
  2. May 31, 2012 at 10:25 AM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    i prefer flat (shows less imperfections, ..is less shiny), ...i use behr paint from home depot, ..i think it's pretty good, their flat paint is washable IMO, ..but if you expect a lot of dings from kids/etc, i'd go w/ the eggshell finish... only use semi-gloss or gloss for trim/etc...
  3. May 31, 2012 at 11:26 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Flat for ceilings , eggshell for walls
  4. May 31, 2012 at 11:29 AM
    medic2230
    Murph
    Bama! Roll Tide
    ^^THIS!
    I've always used BEHR paint.
  5. May 31, 2012 at 11:38 AM
    Dromlace
    Dromlace Well-Known Member
    Michael
    Montgomery, AL
    2006 Tacoma TRD Sport
    Okay here's where me working at home depot comes in handy. I worked in the paint department.
    We carried Behr, Glidden, America's Finest, and Speedwall.
    The last three brands are all under Glidden.
    There's: Flat, Flat Enamel (Flat but washable), Eggshell, Satin, Semigloss, High gloss
    Flat is what most people do in bedrooms. It also doesn't show imperfections like other sheens.
    If you have kids the MINIMUM i recommend is eggshell, the higher "sheen" you get, the easier it is to wash. If they like to touch everything I'd go with eggshell if not satin (not that shiny).
    ALSO, the higher the sheen, the more water resistant it is.
    Personally I like the Behr regular paint and paint+primer paints before Glidden.
    For garage paint, I'd just use speedwall semigloss. It's cheap and washable.
  6. May 31, 2012 at 11:42 AM
    OZ-T
    Peter North
    British Columbia
    Get Bengamin Moore
  7. May 31, 2012 at 12:42 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Yep. And sem-gloss for trim. Just re-painted my trim last weekend. Use Behr Ultra. Primer/Paint in one.
  8. May 31, 2012 at 12:44 PM
    OZ-T
    Peter North
    British Columbia
    How well does that stuff work ? Seems too good to be true .
  9. May 31, 2012 at 1:58 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I prefer Sherwin Williams super paint flat personally. Flat doesn't show the imperfections in the drywall. It's a much better paint than Behr IMO. Also, in my experience of all the painting I've done with it, (with the exception of red) it will cover in one coat without the need of all that Paint and Primer in one bullshit everyone is advertising on TV.
    I have cleaned the walls numerous times with the flat and it has come clean. My golden retriever likes to rub against the walls to scratch his back and he leaves greasy "rings" around the rooms from the oils in his hair. I just use a normal sponge and a little Mr. Clean mixed with water and wipe them down.
  10. May 31, 2012 at 3:59 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Most expensive paint you can afford. Really good paintbrush/roller Put on two coats use semi-gloss.
  11. May 31, 2012 at 4:12 PM
    spares
    spares Canadian Bacon
    New Brunswick, Canada
    06 DCSB TRD Sport
    Go to Dulux and get their diamond eggshell brand. Its super durable, washable and covers really well. Its a little pricey but in the end a bedroom should take at most 2 gallons for 2 coats so it won't be that bad.
    For coverage, paint should go 400 sq ft a gallon, second coat is 60-80% the amount of paint.
  12. May 31, 2012 at 7:28 PM
    wileyC
    Centerville, OH
    i've been using behr ultra of late... i'm very happy w/ it, .. it is expensive, ..but if you're going to prime anyway, it's a nice/easy way of doing it... typically i do two coats of this stuff, ...it is a little more viscous than regular paint, so make sure you stir it up really well before using, ..sometimes the primer component kind of settles out from the paint in the can over time, so good mixing is essential.. ;)
  13. Jun 6, 2012 at 10:43 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    We used it on our condo as well. Two coats pretty much covered everything.
  14. Jun 6, 2012 at 10:54 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Glidden sucks... you don't get what you pay for; it doesn't cover well. Olympic is good and so is Dutch Boy. Everyone says Behr is great, but it does cost a lot more. You should use satin or semi gloss.
  15. Jun 6, 2012 at 8:48 PM
    stuckinoh
    stuckinoh Active Member
    Brett
    OH
    Big Black Truck
    TUNDRA
    I like Olympic low VOC. You can paint all day and barely smell it at all. Won't run you out of the house from fumes. All my walls are satin sheen and come clean good with a Mr Clean magic eraser.
