Interior LED Guide?
Discussion in 'Lighting' started by adaptedtheory, Feb 5, 2013.
  1. Feb 5, 2013 at 10:53 AM
    adaptedtheory
    adaptedtheory [OP] Well-Known Member
    04 Tacoma S-Runner
    Window Tint, 8" Sundown SA-8, Kicker ZX500.1
    Can anyone point me in the right direction on a guide or something for installing interior LEDs and the best way to go about installing them??? Thanks
  2. Feb 5, 2013 at 3:25 PM
    Av8er
    Av8er Well-Known Member
    Taylor
    Formaly Houston, now Tampa, FL.
    09 Prerunner SR5/TRD DC, LB, w/ Tow
    You can check out my build link. Not a ton of info but pics and I can help ya along. Also did a bed light write up. You'll really enjoy the interior LEDs.
  3. Feb 5, 2013 at 6:44 PM
    adaptedtheory
    04 Tacoma S-Runner
    Cool, thanks man. Your bed LEDs look sweet. I just need to learn more about the nitty gritty of the process. Seems like a simple upgrade but for a nub like myself, I just need to learn some more about the specifics. :rolleyes:
  4. Feb 5, 2013 at 7:35 PM
    Av8er
    Taylor
    Yea I hear ya there really isn't anything to it. Very easy switch. Plug and play so to speak.
  5. Feb 6, 2013 at 9:47 AM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    La Mesa
    2014 SSM Trd Off Road 4x4 Auto
    Take and pop a small flathead inbetween the outside of the hard grey plastic and the light plastic. This will pop the map cover down. This is the tricky part. I have some dental tools that I use but anything with a 90 degree bend should work. Put it behind reflector and pop the map bulb out. Putting in the new led is straight forward. If it doesn't light up when you first install it you will have to flip it 180 degrees and reinsert it. The dome is easier. There is a little tab built into the clear plastic. Insert screwdriver in that slot and pop the lense down. Pull the old bulb out. Put new one in. Remember if it doesnt light up flip it 180 degrees.
  6. Feb 6, 2013 at 10:48 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    superbrightleds.com
  7. Jun 21, 2014 at 12:51 PM
    Dirty Harry Taco
    Dirty Harry Taco New Member
    Harry
    Kansas City
    2014 TRD off road spruce mica
    Green LED dome & map lights, Tonneau cover,
    Thanks csjumper2003. it worked great! I put in all green LED's in my truck so I won't lose my night vision.
