interior light/fuse blowing issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LiftedOn35s, Oct 9, 2022.
  1. Oct 9, 2022 at 6:54 AM
    LiftedOn35s
    LiftedOn35s [OP] Graduated!
    Noah
    Northeast FL
    Shadow Grey Met. 2004 Tacoma V6 5MT TRD OR
    1" level, 16" American Racing wheels, 32" M/Ts
    Hey all. Having issues very similar to this thread https://www.tacomaworld.com/threads...-or-running-lights-with-headlights-on.348959/
    2013 TRD Off-Road double cab auto. Stock headlights but aftermarket LED tail lights. The 10A "tail" fuse in the interior fuse box continues to blow out when the headlights are turned on, for a reason I can't find.
    The fuse and truck were just fine and worked perfectly for the first 3-4 months of ownership but recently it blew this fuse for seemingly no reason. Nothing was intentionally changed (no modifications, messing with any wiring, etc.) prior to it blowing that would've caused it.
    Symptoms are that no interior "night" lights work - backlighting on the steering wheel, climate controls, etc. The dimmer switch works so I've ruled that out. You can put a new fuse in, turn the headlights on, and it works for about 10 seconds before it pops.
    Any thoughts would be much appreciated.
  2. Oct 9, 2022 at 7:10 AM
    Waasheem
    Waasheem
    2007 xrunner
    When I have a similar problem I disconnect everything powered by that fuse, then plug everything in one at a time until I find the one that causes it to pop. In this situation, it sounds like a big task to do it that way. So I’d disconnect the stuff that’s easily accessed, tail lights, climate controls. Then see if it still pops. You might want to get a pack of fuses first.
  3. Oct 9, 2022 at 7:38 AM
    LiftedOn35s
    Noah
    Northeast FL
    Sounds good! Definitely a tricky one to disconnect everything so I'll work with what I can.
  4. Oct 9, 2022 at 7:49 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Do you have trailer wiring or an aftermarket radio? I could help with a wiring diagram.
  5. Oct 9, 2022 at 8:05 AM
    LiftedOn35s
    Noah
    Northeast FL
    Stock radio but it does have a factory (or dealer, not sure how it works on 2nd gens), trailer wiring system. I was actually thinking that may be the issue.
  6. Oct 9, 2022 at 8:11 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Here's the wiring diagram for the tail light system. You might want to unplug your headlights, front marker lights and the rear tail lights, turn the lights on (see if the fuse blows) and then plug the lights back in one at a time.
    • TL.pdf
      File size:
      100.1 KB
      8
    TnShooter likes this.
  7. Dec 6, 2022 at 11:46 AM
    LiftedOn35s
    Noah
    Northeast FL
    Sorry to revive a now older thread, but we figured it out!
    The license plate/tag lights were aftermarket pieces and had been very weirdly wired in/connected to the factory plugs causing the fuse to pop! Thanks for the help guys!
  8. Dec 6, 2022 at 1:48 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Thanks for the update.
    Good to hear you got it figured out:thumbsup:
