Interior lights and click stopped working, not the fuse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tjanuskiewiecz, Apr 11, 2018.
  1. Apr 11, 2018 at 4:17 AM
    Tjanuskiewiecz
    Tjanuskiewiecz [OP] Member
    Taylor
    New Mexico/Massachusetts
    2008 Tacoma 5 speed access cab
    2 inch rear lift with toytec shocks and ome leafs - 3 inch front lift with bilstein 5100 shocks, toytec coils, and JBA uca's - 285/75s on 16 wheels
    So I was replacing my interior light the other day and the truck was on probably not the best idea I know. Anyhow it sparked for a second then all the lights and clock went out. The clock would work on and off for a few days but now nothing . The fuses are all fine any thoughts?
  2. Apr 11, 2018 at 4:49 AM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    What sparked, the bulb?
  3. Apr 11, 2018 at 6:56 AM
    Tjanuskiewiecz
    Taylor
    Yea that’s what it seemed like...
  4. Apr 11, 2018 at 3:15 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Did you read the fuse with a meter or just look at it.
    Hint: you cannot tell visually if a fuse is compromised.
  5. Apr 14, 2018 at 5:09 AM
    Tjanuskiewiecz
    Taylor
    I did not but I replaced the fuse and no luck
  6. Apr 14, 2018 at 5:24 AM
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    Something similar happened to me.. clock and everything went out, but replacing the fuse under the hood fixed it.
    :confused:
  7. Apr 14, 2018 at 5:26 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    you may have blow the new bulb as well. Try another new bulb??
  8. Apr 14, 2018 at 6:27 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    The only thing in common between the clock and the dome light is the 7.5 amp dome fuse. What isn't working the dome light, the clock or both?
  9. Apr 14, 2018 at 7:08 AM
    Canufixit
    New England
    ^----- That's the question I should have asked!
    Old Guy's rule ! You can tell a young-un the answer but you can't make him listen !!! (What?)
    Jimmyh[QUOTED] likes this.
