Interior Lights indicating door is open won't turn off???
Discussion in 'Lighting' started by rjporras, Jan 24, 2012.
  1. Jan 24, 2012 at 3:42 PM
    rjporras
    rjporras [OP] Active Member
    PhatCheddar
    DURANGO
    99 Tacoma Extended Cab
    6 inch Fabtech Lift Air Lockers, front and rear Premier sound and alarm Leveler
    I have a 99 Tacoma and hoping some of you might have some ideas as to why my interior door lights won't turn off. the little "plunger" switch seems to be clear. I also saw somewhere could be a dirty MF?? The dome lights turn off btw. so i'm really confused.
    Need some help from you smarter folk..lol.
    Thanks guys
  2. Jan 25, 2012 at 11:12 AM
    DelTaco
    DelTaco Well-Known Member
    DELAWHERE
    '17 TRD Sport DCSB
    Close your door....... :D
  3. Jan 25, 2012 at 3:35 PM
    rjporras
    PhatCheddar
    DURANGO
    hahaha i tried slamming the door. I am going to put some wd40 on the plunger thing that gets pushed in when door SHUTS lol.
  4. Jan 26, 2012 at 8:03 AM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    You could try disconnecting the battery. It resets the internal computer. Could be worth a shot.
  5. Jan 26, 2012 at 8:11 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    The circuit doesn't run through the ecu
    Bad door switch or integration relay. (leaning towards a door switch)
    Take one switch out and disconnect a wire. If the light goes out, it's that switch. If it stays on, reconnect the switch and do the same to the other. Make sure the opposite door is closed when you do this.
  6. Jan 27, 2012 at 7:18 AM
    rjporras
    PhatCheddar
    DURANGO
    Thanks!! I'll try that tonight. I knew i could get some help here. If you're ever in Durango, i'll buy you a beer :cool:
