Interior lights on Gen 1
Discussion in 'Lighting' started by doc1911, Oct 3, 2012.
  1. Oct 3, 2012 at 4:57 PM
    doc1911
    doc1911 [OP] Well-Known Member
    NC
    2018 Pro
    I just got LEDs for my dome and maps light on my 2004 Gen 1. Here are my questions.
    Has anyone found an easy way to tie the map lights in the front to the dome light in the middle so that the map light will come on when you open the door? In other words, make the map lights work like the dome light with a ON, OFF, and DOOR function?
    Has onyone found a clear replacement lense for the dome light? Mine is milky and the map lights are clear.
    Thanks
  2. Oct 4, 2012 at 4:32 PM
    doc1911
    NC
    2018 Pro
    No one?
  3. Oct 4, 2012 at 4:38 PM
    Aw9d
    Aw9d That one guy
    I don't know if it works for the first gen but there is a mod for the second gen that works.
    Edit:
    Shit did some searching and found this for first gens.
    http://www.tacomaworld.com/forum/1st-gen-tacomas/209327-cheap-dome-light-mod.html
    The map lights work as normal but if you set the dome to "Door" or "On" the map lights will come on as well.
