Interior lights
Discussion in 'Lighting' started by chadderkdawg, Aug 30, 2011.
  1. Aug 30, 2011 at 7:41 AM
    chadderkdawg
    chadderkdawg [OP] Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Curious if anyone has always-on interior lights. In my Bimmer I had a real dim orange light that shined towards the console cubby and cup holders, it was kinda nice.... anyone have anything like that here?
    Cheers :thumbsup:
  2. Aug 31, 2011 at 12:00 AM
    Linelock4
    Linelock4 Member
    Jared
    New Hampshire
    04 Extra-cab V6 5-speed 4x4 Limited TRD
    Spectra intake and Air-Raid throttle body spacer.
    I think you mean key on lights for the interior. The easiest way to do this is to you leds with resistors to cut the brightness. You could even use a relay to cut the brightness more when you turn your parking lights on. You can get all the parts from Digi-Key. I just quickly did a drawing of how it should be done but I can seem to attach the drawing to this post. If you want give me your email and I can send it to you and answer any more questions you might have. I did professional car audio for 15 years and I had to do this very thing for many of my customers.
  3. Aug 31, 2011 at 2:41 PM
    sook
    sook Well-Known Member
    Chandler, AZ
    08 Sport PreRunner SSM dbl cab sb
    Avid Offroad light bar, Steelcraft step bars, Extang Revolution tonno, TRD black chrome headlights, 09 LED tails, all window tint, OEM DTRL w/ GM shorty bulbs, tailgate hose clamp, fighter pilot with red cold-cathode, Pioneer AVH-4300BT
    Check the group buy section for flyeyez designs
    Search for interior led, interior lighting, led cup holds, fighter pilot mod, cock pit mod
    I used 12" cold cathode computer tube lights in my foot wells and wired them to the rest of the "parking" lights
  4. Mar 7, 2012 at 4:36 AM
    Honey Badger1
    Honey Badger1 Well-Known Member
    Trip
    New Hampshire
    2011 Tacoma TRD Sport
    Fuzzy Dice, Fighter pilot mod, power ports always on, GPS wired to come on as key is turned, LED Map/dome lights, all weather mats, bed liner, tool box on rail system, Tinted tail lights, repainted badges, Home made grill, Light mounting bracket with two 6 inch. PIAA Drive lights, Stealth mod DTRL on/ off, leather arm rests, door and center.
  5. Mar 9, 2012 at 5:32 AM
    Nicko
    Nicko beach bum
    Nicolas
    South Florida
    nice lighting !!
    I had the same idea to do it just like that
    with the lights under the dash. But Im going
    to do mine in red.
  6. Mar 9, 2012 at 6:33 AM
    jkirkpatrick
    jkirkpatrick Well-Known Member
    Edmonton
    2000, build thread soon
    Stealth sub box, total stereo overhaul, 883 OME with Nitros, Dakars, All Pro bumper, Engo 10,000lb winch w/ synthetic line, ARB rear locker, All Pro full skids, All Pro sliders, 7069 Pro Comp with 285/75/16 Duratracs, front sway bar delete, CBI rear bumper, regeared 4.88
    OP - if you're first generation and you have the overhead console with the two light swithches, you should be able to tap into your headlight switch, drill a very small hole in the console, and mount a LED to shine down on your console.
    I'll be doing this myself, but not until this spring/summer. Light switch tap in as you don't want it on all the time. One LED should be neglible power draw. I'm using a red LED myself.
  7. Mar 10, 2012 at 6:09 PM
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    Nice lights HoneyBadger. I just installed the wired Flyzeye Design lights in my 2012, and they are great! I did the Blue/white with red halo. If you order from them, in the comments section, put your TW screen name and you get a $10. refund check with the order. Good people and nice lights.
  8. Mar 12, 2012 at 6:34 PM
    Nicko
    Nicko beach bum
    Nicolas
    South Florida
    thanks for the info,
    when i finish with it ill definitly post
    up the results,
